Hi all,
This has probably come up before but I can't find it... I have a really loud squeal that lasts for a few seconds on a cold start... usually it's worse with colder weather (lasts longer). I've had 100,000K service done (replaced all 3 accessory belts) and that helped it a little, but still there (actually I think the warmer weather may be what helped).
So I'm suspecting the viscous clutch on the crank-driven radiator fan... has anybody had to replace one of these? Would any old R31 clutch fit? Thinking it might be cheaper than one of an RB25.
Thanks
DaveB
https://www.sau.com.au/forums/topic/238228-loud-squeal-at-startup-cold-start/
Do the belts feel tight? you should only be able to deflect them a small amount - if you have heaps of slack in it then thats a good sign tehy are not tight enough
the belts might have stretched marginally after install
Thanks for the quick replies guys; unfortunately though -
- noise was there before the service
- they replaced & tensioned the belts, and they are pretty tight - fair effort is required to deflect them 10mm or so on the longest span, I always suspected they were too tight even (old ones were tight too)
- I had the water pump replaced during the service... along with idler & tensioner bearings (which I also wondered about)
I've actually had this problem since I got the car, about 25,000 K's ago. It has been intermittent; doesn't always make noise. When I couldn't tighten the belts, I just suspected the radiator fan. I was going to use some 'belt grip' spray but it says specifically 'do not use on multi-V belts'??
Um, first of all, Belt grip - do what it says and dont use it on ribbed or multi V belts. Belt grip is designed to work on higher face pressures than you get with these style belts, all it will do is cause your belts to wear out faster.
Secondly, check your air conditioning clutch. Looking at the face of the compressor, you will see that when the air con is off, the centre of the clutch should stay stationary. If the clutch is on its way out it can drag when you start up.
Fan clutch - If this is the problem they usually get more free as they deteriorate, not bind up. You should be able to feel a slight resistance when you turn it by hand (with the engine NOT running) but in my experience, like I said, when they start to let go they get easier to turn, not binded up. Maybe check and make sure there is no movement in the hub of it though - if the spigot is worn it may be letting the fan come in to contact with the shroud.
Lastly, make sure that the belts haven't been over tightened, as this can cause the bronzed bush in the water pump to bind and wipe the shaft. Deflection should be as per the manufacturers recommendation.
Thanks Dale, I hadn't thought of the air con compressor. Hope it's not that!
Yeah the sound is *very* annoying... especially when it's late at night/early in the morning... sure wakes up the neighborhood...
If it is, the VL commo one can be adapted to fit pretty easily. Same for the alternator
Excellent... for the NEO engine as well?
checked for like, dead cats?
Lol! first time it happened I thought I'd killed one...
My old s2 stagea used to do that noise on startup. Would disappear about 2-3 seconds later. Also I found that I could turn the car off and on again, and it would usually be ok the 2nd time.
I think I ended up replacing all the drive belts, which solved the problem for me. I think the squeaking was the belts slipping a little before they warmed up.
my S1 is a bit of a squealer also. the other night it squealed like crazy and destroyed a belt. turns out the alternator was knackered. glad i got that extra warranty now :D even with replacement alternator and belt, and i'm back to square 1 with a squeaky belt a week or so later. damn japanese, why do they always have to be so mysterious :)
my S1 is a bit of a squealer also. the other night it squealed like crazy and destroyed a belt. turns out the alternator was knackered. glad i got that extra warranty now :( even with replacement alternator and belt, and i'm back to square 1 with a squeaky belt a week or so later. damn japanese, why do they always have to be so mysterious :(
damn, hope I haven't got that problem... new alternator must be a couple of hundred at least. Good thing you had warranty.
Pixel8r - :D those are my exact symptoms; everything is the same. Unfortunately though I have had all 3 belts replaced like a couple of weeks ago; I don't know what's up.
PS You're trading up to an M35??? anything u didn't like about the S2 (besides the squealing?)
  • 3 weeks later...
my S2 is exactly the same
Well so far I think that my problem is just a loose belt. It only happens when I have let the engine cool down, and if it's not completely cold, it's not as bad (squeak doesn't sound as loud or last as long)
It just sounds like a belt slipping... so I got to it and had a look for the belt adjustments. I have found 2 of the 3 belt adjusters... they are 12mm bolt heads and just require a 12mm spanner (ring preferred, but access to the right-hand-side one for the power steering pump belt is a little limited, you may need an open ender). None of them need to be too tight; just until you can 'deflect' the belt using thumb and forefinger about 10mm along its longest run.
Here are pics of the adjuster locations for the 2 that I have found:
Left side (alternator/cooling fan belt)
Right side (power steering pump belt)
Centre belt (air compressor); I don't know where the adjustment for this one is (I suspect I'd have to pull the underbody plastic off and crawl underneath)
Unfortunately for me, it is the centre belt that feels loose while the others feel damn tight. I am sure it's that one which is causing my problem, but after feeling around everywhere and getting filthy and burnt I haven't been able to find the adjustment yet.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
