nope, wasnt it..... well, it idles a little bit better, but still has a massivly loud
boost leak.....
im bout to have a look at the intercooler piping behind the front bar.
this is better than day time telivision for all you mofo's aint it!
you love it.
  • Replies 120
Posted Images
Its a simple process of elimination ... fix all the obvious points, and eventually you'll find the problem.
It will also save you some labour time with the mechanics when you can tell them what the problem is not.
yeah, ther is a pipe that goes from the front of the plennum, to the left cam cover,
the plug is making a hissing sound, and upon further inspection, the plug going inot the cam cover is broken..
still dosnt fix the boost leak though..thats my main concern atm
maybe it is a rooted turbo :)
boost leak.....
if it's so loud cant u just chuck ur head in the engine bay and listen for it? get someone in the car loading up the engine etc.
i tried that, it onlly does it when on boost driving.....
doesnt do it free revving in the driveway from what i can hear.
fixed up the hose to the cam cover, but still idle shit and
blolwing shit loads of smoke now.
although have you checked your boost controller?
my old 180 blew alot of smoke once, it was because a breather hose on the rocker cover crimped itself, which stopped it from breathing, and resulted in a heap of smoke.
Edited by ted180
well heres what i replaced today
oil catch can hoses (blue silicon heater hose)
throttle body/cross over pipe joiner
top radiator hose
took the mesh out of afm
and thats it.
every thing else went back on as it come off
i have offered you the solution yet u still refuse to help yourself
why?
if you dont have a compressor drive to the servo and do it there.
turn your car off, open the bonnet, undo your afm install freezer bag and then reinstall afm
it takes 2 minutes and by doing this test it will act as if your car is on boost and therefor expand the hoses enough that they will piss out air.
without your car running it is easy as to hear if and where you have a leek.
2 minutes and then you can tell everyone where the leek was.
well it does sound like your leaking air, if its on the wrong side of the AFM it can do lots of bad things, like put in too much fuel. the AFM is really easy to break. and if you have a oiled pod the oil can foul the little wire inside it, and cause havok. if you took out the mesh in afm i suss you might have accidentaly hit the wire. have you looked inside the AFM to see if its still ok? really fine wire you might need a torch to see it.
one thing you might try is a squirt bottle full of soapy water , if the car runs spray it around the gaskets/joints while idling, you will notice the engine will fluctuate in RPM or die if you hit a leak, just dont spray it into anything electrical or spark plugs or AFM intake. the soapy water will sometimes blow bubbles when it finds air leaking . a vacuum cleaner hose is good to hear air leaks as well, just hold it to your ear and move it carefully around the bay when u hit the leak it will be loud as.
the fuel pressure regulator has a vacumm type hose on it if you pinch it with your fingers slightly when running the engine should change the idle speed a bit. (not sure about your regulator model)
are you sure the cross over on the throttle body is sealed up good with clamps, if not that can cause your symtoms
is the smoke black or blue, white? i thought you said black. does the motor sound like its miss firing at idle or 3-4k?
if its a vacuum leak it normally runs fast or slow on idle unless its in one of the power curcuits or AFM
what part of town do you live in im off work this week and if it south i can pop over for a look ?
let me know
cheers hope u get it sorted
why?
i agree have you tried this trick, i think both of us think your AFM is confused...lol
why?
Damo
black smoke is too much fuel or fuel ratio stuffed
white is blown head gasket=water in combustion or even a bad seal in a water cooled turbo
Blue is oil in combustion process, turbo seal, rings, valves, or even headgaskets if blown in the right spot
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
