i need to find one single second hand wheel of the volk challenge wheels (as seen previously on leewahs car) but instead of the blue its got red, i have the oppertuntity to buy a set of 18" volks for $700! only thing is one wheel is buckled (front) but otherwise the rest are damn fine.
i wanna buy second hand as new would be to much for me
they came off a gtst so they fit already, i think i need tyres but doesnt matter, the wheels are cheap!
please guys help me out as soon as possible
https://www.sau.com.au/forums/topic/23854-help-me-find/
well its a front one, and apparently the rears are verrry wide, yet it was off an r33 gtst, so he's bringing one front and one rear to work tomorrow, see if it fits, and even if i have to buy a brand spanka from takakaira or something i will still have leet wheels, but if i can find one second hand one then yippee
they are silver with red, instead of blue like daves
https://www.sau.com.au/forums/topic/23854-help-me-find/#findComment-510628
I bought a set of second hand wheels for my R30 - 2 had been damage, like run flat, badly pitted around the tyre seal.
The guy I got them from managed to get them fixed - said he didn't believe they were the same wheels when he picked them up.
I don't know where they were done (somewhere in Heidelberg) - see the guys at Beaurepaires in Bayswater and ask them about the RS Impul wheels.
https://www.sau.com.au/forums/topic/23854-help-me-find/#findComment-511587
hmmm yeah i am going to see them tomorrow and hopeully i can find someone to fix the buckled one up because i really cant be bothered buying a new wheel from japan and also paying that amount, but will if i have to
https://www.sau.com.au/forums/topic/23854-help-me-find/#findComment-512172
nah i was gonna buy one from takakaira, and donallens can get them apparently (checked their site) but i want to see how badly this wheel is damaged (hopefully he brings them to work tomorrow) so i know if i can fix it or just have to replace
cant wait :P:)
https://www.sau.com.au/forums/topic/23854-help-me-find/#findComment-512873
yep they advertise per wheel
i tried the rear wheel on my car
GOD DAMN IT LOOKS AWESOME!
its silver with red instead of blue like leewah's
i love them
rear's have 275's PZero's
fronts i forgot
only thing is the front buckled wheel
he's gonna bring it to work tomorrow, gonna take it to tyrepower (who helped me out a lot today, wheel nuts were threaded, he took them off for me, sold me new ones for cheap, and also a set of locknuts for $10 :) :)) get them to see how buckled it is, if its fixable then i'll take it this guy in heidelberg he recomended (maybe same guy u were talking about blind-elk?)
if it cant be fixed then i will be sad but wont be to upset
the $700 price tag was per wheel, i didnt hear properly, but he said $1500 for me :):P with tyres
i hope this can be fixed, they look awesome, i think the rears are 18x9 or 9.5!
its crazy!
front might be 18x7 or 8 hehe
https://www.sau.com.au/forums/topic/23854-help-me-find/#findComment-514057
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
