  • Replies 116
Posted Images
I have one for a 350d or any other *** series canon.
5 bucks??
if it doesnt work will return money back.
I know it works for a 350d 100%. Just not sure about a 400d or 450d or 300d. im pretty sure it works!!
Anyone keen?
i'll have to pass - i have a D80 :O
so i need this one: http://www.d-d-photographics.com.au/nikonslracc.htm#mc-dc1
but too exxy so just gonna get this one for US$4.55: http://www.dealextreme.com/details.dx/sku.8245 :(
ps. bought this from them not long ago (go free shipping) and was quite impressed that it works and with the quality (expected it to be VERY cheap and crap)
http://www.dealextreme.com/details.dx/sku.5483
Thanks basti :rofl: means a lot
However i don't get what you mean by this "but the mooring post in the foreground of 1 really sets it off for me"
Is that a good thing or bad thing? lol
Edited by siddr20
Thanks basti ;) means a lot
good thing. gives some detail for the foreground and really contrasts with the water
cheers man :P
Im gonna go back there again after exams and experiment more.
Was only there for 15mins as i stopped by quickly on the way home one night.
dodgsum - heheh man i love that shot :( Makes it look spooky!! great work!!
Edited by siddr20
You should re-colour the median lines in the 2nd one to a yellow colour, Dodge. - Any normal person would think it was taken in Arizona somewhere. :)
My contributions this week...
The following images are links instead of posted images as they are not safe for work.
http://i15.photobucket.com/albums/a383/Xme...ey/IMG_6092.jpg
http://i15.photobucket.com/albums/a383/Xme...ey/IMG_6121.jpg
They aren't my hands in the last shot either. :P
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
