I suspect my LSD is getting tired so I'm investigating a newie. I've come up with the Nismo Pro 1.5. It comes in 2 versions, one of which is adjustable for how much it locks up. It has three settings (low / med / high) depending on what use you've got for it. This can be adjusted externally on the side of the diff housing with a socket set. All you got to do is get the car on a hoist or some ramps / stands and away you go. Cost difference is $170 so negligible in the scheme of things....
So the question is.....in the real world how useful would this feature be? And is it reliable? I guess it's Nismo, but it also sounds like something else to go wrong.....
Thoughts?
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/
Best advice is to down load the manual off the Nismo website & see for yourself how easilly (or otherwise) the pre load can be adjusted. Then decide if it is a useful feature. For my 10 cents it is not worth the effort. They are an agressive diff in anycase, irrespective of the setting.
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4173338
Perhaps then the lower setting would be useful for the road? Given occasional track use and some road use what other diffs do you think I could be looking at?
Thanks.
I have a GT Pro and have it set on the lowest pre-load setting... its still really aggressive. If you wear semi-slicks it will really bang and crash in the rear end as it loads and unloads.. wearing street rubber, it will still 'chatter' the tyres in tights turns at slow speeds just like a locked diff.. but its not so bad on streets. If it were your daily driven car - it would annoy the b'jesus out of me and is possibly pretty hard on your tyre wear.. If its more Sat/Sun and track days - its a great option.
I would investigate the GT Pro TT if I were you - same diff but slightly less aggressive. I haven't tried it so can't say how much less..
The other one I would look at, just from what I have read, the ATS Carbon..
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4175369
Thanks for that. It will have R spec and won't be a daily but that all sounds like a lot of agro. I was told by the supplier the TT was for track use........Best I do some more research.
Any other opinions or experiences out there?
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4175463
Yep TT is for track use (so is the normal Pro - that's what I use it for). The difference is the Pro has a 55degree ramp angle and the TT has a 45 degree ramp... the idea I believe is that the TT locks up a little more progressively that the normal pro - and that makes it a little more friendly through corners.. (apparently).
If it is not for daily though, the Pro is a very good diff and you'll find it hooks up great.
Good luck with it anyway.
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4175574
I have the TT Pro in my 32R. Sure it hops a wheel but it makes the rear feel more predictable IMHO. Do it! The TT is fairly easy to live with although I wouldn't want to use it in a daily.
Have a read of this interesting diff thread
Thanks. so did you put the Nismo kit in your std diff?
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4176041
OK. So I've been on the Nismo site and yes the TT is the milder diff, contrary to the advice I thought I'd been given by a vendor! Sounds like that'd be more suitable for my application. Next hurdle is the 1.5 way versus the 2 way (or other brands.....). I understand the std R32 GTR rear diff is a 2 way, but that it is quite a slack diff? So not too aggressive. I also understand the 2 way locks as much on decel as accel, but don't beleive that this relates specificaly to how aggresive the diff is e.g. the skipping and chattering etc but this inference seems to have been drawn in some threads.....?
So, what is the effect of a 2 way compared to a 1.5 way both in terms of its livability day to day and its performance as a diff when its doing its stuff (its....)
Thanks.
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4176630
Yes the stock GT-R diff is a 2 way, but there is much more to it than that.
Firstly the preload on the stock diff from factory is ALOT less than the NISMO item.
Secondly you don't need a diff that locks on the over run in a GT-R - it serves no purpose other than to exacerbate the GT-Rs inherent handling faults, ie understeer.
Third as long as your ATTESSA system is working correctly (ie not worn out) you don't need much in the way of a rear diff. An Attessa controller will eliminate any last vestiges of wheel spin so get one of those instead of going too hard on the diff.
There are two parameters for how aggressive a diff is - the preload & the ramp angle. More preload = more aggressive. More ramp angle = more aggressive.
Lastly check the other Nismo options.
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4176791
Great info. Thank you. Yeah, good point re the 4wd system. I guess I have a switch to 'lose' the fronts for a little sideways action so am interested in the diff as a 2wd set up too.
I'll look into all the points you've raised.
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4176891
^...and it scares small children and old people. lol
Nope. Pro TT LSD...I like it. Not too clunky at the factory setting. I'll see how I go when I get a chance to try it out at the track
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4178328
The ATTESSA controller, is the Ruzdic engineering the one to go for? Are there alternatives? Be interesting to read up on these. Thanks for your input.
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4180484
If its for circuit/track then yes. I use one. Probably no good for drags as it doesn't take the longitudinal G into account... only lateral. At least that is my understanding of it. So launching is just the same as stock more or less... only in the twisty bits does it come into play.
Haven't had the opportunity to drive with any other though, so can't make back to back comparison I'm afraid.
https://www.sau.com.au/forums/topic/238720-nismo-pro-lsds/#findComment-4180551
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
