changing water pump rb20
i used a VL RB30ET water pump, you need a rattle gun to put the crank pulley bolt back on or else youll be in trouble.
other than that its just a process of pulling the radiator, fan and belts off - have a look on the net as theres some documenation on the RB20 engine which may be of use.
  • 4 years later...
any1 knwo where a guide for this is ? also, if i dont have a rattle gun how can i undo and do up the pulley at the bottom of the motor to get the lower half of the cam cover off
its fairly easy once you get all the covers and harmonic balancer off, if you've changed a timing belt yourself you should be able to do a water pump.
put the car in reverse, get someone to put thier foot on the brake, and use a long breaker bar. there is another way buy putting a big screw driver in somewhere but i dont know that one.
Edited by QWK32
NO!!!!
You need the fastest gear in the box, not the slowest.
Unfortunately 5th is a relatively weak gear as it drives via the layshaft.
The strongest and fastest gear therefore is 4th (direct).
NO!!!!
oh ok. the only reason i use reverse is so the car doesn't move forward onto me :(
will the car stay still if you use 4th?
You're not thinking it through.
If you select say 1st or reverse, it's dead easy to crank the engine through the brakes.
Select 4th and the brakes at least have a chance of holding, and most importantly it's the strongest gear.
yeah, i realised that after i posted. cheers.
Its a good way to learn more about the car if you do it yourself, just make sure you do the timing belt properly.
yea id go the breaker bar. try putting heaps of wd 40 on the harmonic balancer bolt the night before to losen up the bolt a little. yea put it in 4th and rip up the handbrake and it will do the trick.
And QWK32, im pretty sure with the screwdriver trick thingy u need to take the starter motor off and u have to jam it in somewhere to lock up the gearbox. Its how you are supposed to do it in the skyline manual.
I personally wouldnt go RB30E pump.
They are NOT the same, and from what Ive seen with people using them on RB20's they have caused cavitation and therefore temp issues.
For the money atleast get a proper genuine RB20 pump for the extra $50 its cheaper than replacing a cooked engine....
Personally Next time I get a water pump Im going N1 for the price they look the goods.....sit one side by side with a stocker and you will see what I mean.
An RB20 may not be as special as a 25 or 26 but TLC does not go un noticed with any engine :D
breaker bar, crank it over and it will loosen itself on the chassis rail...
not the ideal way of doing it, but it works...
i was waiting for someone to sagest this.
also what about select a gear and put a secew driver in one of the tail shaft universals levered against the floor. that should hold it all still.
i looked into putting an N1 pump on my 20 a year or so ago and was advised that the N1 pump is designed for higher reving track work and can cause a car to over heat in city trafic as the dont circulate enough water at low rpm. track work ideal but not dayly driver.
im sure you can get a genuine nissan rb20 water pump for around $100 out of nissan but that my have been trade price.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
