Need to find out how hard it will be to change from my gt30 turbo on my rb20
that is a top mount manifold and external wastgate too the tdo6s L2 8cm turbo?
im not too sure on all the flange sizes of my turbo setup as the car is getting a make over.
and is it possible to just buy the tdo6 with out the full kit? and anyone know price for just the turbo?
https://www.sau.com.au/forums/topic/238932-changing-from-gt30-to-tdo6-on-rb20/
Ball park figures... Turbo $2200. Remove, modify and re-fit your top mount manifold with correct 3 bolt flange will be about $400-600 including new gaskets. Then you will have to modify your dump pipe, water and oil lines, and intercooler piping so throw another $500 easy at it.
I would think a 3071 with a 0.63 A/R exhaust housing is effectively a bolt on option. Hell even cheaper again would be to just try a smaller exhaust housing on your current turbo....first things first though you really need to find out eactly what turbo your currently have. There should be a tag on the centre cartridge that would help suss it out
If i was in Vic i would let you take my car for a spin but am OS with work at present. Perhaps hunt down someone else running the TD06, it woudl be a shame to go to all that expense and find you were not happy. Isnt your motor a built motor? What compression did you end up with?
Maybe one of SAu's turbo propellar heads can compare the size and trims of the wheels of the two respective turbos. The TD06 seems to work well on the RB20, but if the wheel sizes are about the same then you can expect the same ball park sort of performance. Have a chat with RE Customs, i am sure he has seen TD06 SR20s and he has a 3071 on his SR20 so may be able ot help you make in informed decision
ok yeah just seems like the tdo6 is way better all over any other turbo for this power
its definately proven itself the 3071r doesnt convice me yet but its still an option just wanna way it all up first
my turbo has a .63 rear. and yeah my engine is completly rebuild with forgies ect ect not sure on compression?
from what rob has told me at sabbadin my engine is a pretty good build compared to others he's seen but then again i know nothing about engines and just put my trust in him.
he said a 3071 would be good and told me from the tag that my turbo is like a 3540 or something in that range
the car is getting painted atm i will have it back this week so i can check the tag again for the spec's on it
just hard to go against whats been proven all the data ive looked at shows tdo6 is clear winner for power on the 20
anyway i wil go see ray at RE and ask about the 3071r im sure ill be happy with it if i bolt it up.
i would be happy with mine apart from late spooling of it.. for the power im making after de-tuning i might as well have gone with the 2530
i want a minimum 250 255kw all day every day if it came on earlier with my setup like the tdo6/3071r i would make the 260kw after the detune easy
I know that TD06's are used on Evo Lancers and Rexes though the Rex ones are not reverse rotation like the I think E4-9 are so a bit more conventional .
GT Pumps here in Australia make up Mitsy based turbos based on the Trust spec TD06 SL2 turbine though I wouldn't think they would be super responsive things on RB20's with bigish turbine housings .
I'm not sure what is available for the upper end of the TD04's (TD04HL) and TD05H turbine housing wise but some OEM Volvo IW housings have a mount flange that is similar to single inlet "T3" .
In TD04HL there are 6 and 7cm housings and I believe 7 and 8 for TD05H .
If it were me I'd be more concerned about the boost threshold and having a reasonably wide effective power range , something getting on song at ~ 5 is a bit much I think .
Roy I think you've mentioned at times that HKS GT-RS turbos (RB spec) work pretty well and are a bit easier to fit not having the external gate .
Thats what I think I'd be looking into .
Cheers A .
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
