ok so as planed i booked the car in to make up a new intake pipe at sureflow and pick up a new dump pipe and clmap from otomoto.
so come friday morning im on my way to pick up the car, jump in and crank it over. the car starts but is only running on 3 cylinders! BAH!! so i thought ok plugs are flooded because car is running really rich so i take them out and clean them, remove all the fuel from all cylinders, crank her over and she is still missing! ended up having to go thru the elimination proccess
1.plugs
2.ignitor modual
3.coil packs
4.ecu
ect
all of the above were working fine...
i was out of options, the only other possible issue that came to mind was the second hand s15 injectors that i installed. so off came the plenume and the fuel rail! as i was removing the fuel rail 1 injector just started pooring out all over the engine like a tap!
so i removed all of the injectors from the rail and found that 4 out of the 6 seals were broken! ahh last thing i wanted on the day that the car was booked in for some work. so of i went down to nissan, picked up new seals and the injectors went back in. cranked her over and she started firing all cylinders. YAY!
was time to take her down to otomoto to pick up a new dump pipe and clamp and re-book a time with sureflow. on the way there in 4th gear on a hill we put her underload to test boost levels, only to find she hit 18psi !! oh !@#$ another issue.
so i picked up a 38mm external gate that is going to be welded on to the turbo housing.
the car is now apart, will be welding the wastegate next week.
yeah mate told you they have boost issues
not sure how ur 38mm is going to go but it SHOULD hold boost fine.
i went 50mm to be safe. u only gotta look at the size of the hole inside the housing its tiny and thats why it creeps lol
good luck with it! keep us updated
yeah i had a feeling that was going to happen :wave:
where did you get yours done? how much?
:spank:
well im not from a city but a small town, i got my mech to do it, he didnt charge me much at all, pulled turbo off,welded up inside of turbo,welded all new gate on, and screamer pipe, and tuned it, cost stuff all lol very pleased
  • 4 weeks later...
ok the car is complete and we have the final results :P
and let me tell you it was a pain the back side to complete! after welding on the external gate and fixing boost issues I was only to find 50km later the turbo blew! BAH was that annoying since i've now pulled it off about 4 times!
anyways otomoto replaced it without question, failure was due to a faulty seal i guess it happens :down:
i completed the setup with new braided water lines, gaskets ect so the setup was now solid.
the car was installed with:
(stock rb25det)
kkr480
38mm external wastegate to atmosphere
kkr dump pipe
trust front pipe
fujitsubo exhaust
apexi power fc
splitfire coilpacks
iriway 7 plugs
z32 afm
s15 injectors
bosh 040 pump
hybrid fmic
hybrid ebc
paul at pulse racing did the tune, end result was 250rwkw on 17psi. the turbo performed really well until we took the boost past 15psi then we hit a massive flow issue. it made the same power on 15psi as it did on 17psi. boost started dropping of back down to 14psi and wouldn't want to go anymore which is really strange with an external gate...
main restriction was in the turbo housing and dump pipe. the otomoto dump pipe is just way to restrictive and just doesn't flow anywhere near enough. also inside the exhaust housing there was turbulence due to the internal gate being welded shut and creating a pocket with resulted in loss of power.
the end result however was impressive, 6000nm of torque and 250rwkw was plenty to play around with. if it wasn’t for the flow issues with the turbo design we should of come close to 270rwkw+ and that’s very impressive for a dodgy kkr.
so in the end it would of been probably cheaper to go with a nice garret due to all the setbacks the kkr gave us. but once again happy with the results and so is the owner :thumbsup:
cheers!
:cheers:
so the moral of the story is dont buy kkr turbos
defiantly better off with a quality product such as garrett, trust or hks.
kkr is not all that bad but it’s a little laggy for the amount of power you get. i guess it’s as simple as "you get what you pay for" in this case.
if your on a really strict budget and you can get the internal waste gate to hold boost (it's probably impossible) then it’s ok for someone who just can’t afford a garrett.
in the end of it all the owner was happy and so was i.
cheers!
nice write up.
does it feel strong to 7000rpm?
thanks mate.
it’s very strong all the way thru the rev range and rev limiter is at 7200rpm from 3rd gear onwards you really start to feel the top end power if you keep pushing it.
the car feels responsive and easy to drive, just a shame for the flow issue otherwise we could of seen some really nice power somewhere around 270rwkw+ the owner doesn’t want to spend more money to fix this issue.
yeah thats a bit of a bummer.
i got same mods just a bigger 50mm ext gate, i control my boost from the gate spring, has 14psi spring and ive tighten it to hold bout 1.4bar 19psi in top gears.
im not sure on exact power figure as it kept slipping the tyres from camber on my mechs dyno but was around 320rwhp b4 the slipping,
my mates 33 with gt30 and all the goodies has 350rwhp on 14psi and we are pretty even if we have 100-200 rolls maybe even half a length infront...who knows
id love a gt35r though...make same power on 1 bar not 1.4
i bet it feels much nicer to drive with the gt30 in it? he would probably have you for response and off the lights.
and again 14psi is not that much strain on the good old rb25, why didn't he up the boost to around 16-17psi? would of got close to 300kw with the right setup.
i guess kkr is not bad for the price... :banana:
yeah man its very smooth power delivery and good response .63 exh .7 front cover..
he wants to eventually run 18psi but having boost creep issues with tial 38mm gate..not holding boost properly once he tries to wind some into it...
yeh kkr arent 2 bad for price...screamer pipe on 19psi sounds animal specially wen u jus pop limiter and makes a huge crack noise haha
hmm thats strange, the 38mm should be just fine for that sort of application, i suggest looking at the ebc before anything els.
yeah the screamer is really nice, i set one up on this setup and it sounds awesome :(
:banana:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
