Ok i have recently brought a r32 with a rb25det in it. It is stock apart from a full 3'' exhaust and a FMIC. I am also running a hks power filter and a boost controller. Also got a malpassi FPR and a walbro fuel pump.
It is tuned at 185.5rwkw at 11psi. It was running pretty shit and the tuner said it had a really bad lean spot in it. He then upped the Fuel pressure by fiting the FPR and it was ok for a while. I then had intermittent problems of the car coughing and spluttering. Kinda like a massive missfire when changing to second gear. It was normally when turning a corner or entering a drift. I checked the fuel pump and all was ok apart from the fact that the pump was only getting 8 volts. I then ran a whole new wire on a circuit breaker and a relay so now it gets 13.4 volts.
The problem went away for a while but now is back. Has happened the last two days. As far as i know it is still on 11psi or lower. Could it be a boost spike or spark. I am really unsure and every time i take it to the tuner it doesnt do it. (f**k i hate that). Any suggestions that might help i am all ears.
Also i searched but cant find anything on this R&R and stock ecu boost problems over 10psi. Can you shed some light on that also Thanks.
Forgot to mention it is running a stock ecu and the Airflow meter is hitting 4.9 volts on 11psi. Been told it may have a high flowed turbo maybe. Cheers
Edited by super_s13
https://www.sau.com.au/forums/topic/239076-problems-with-rb25det-in-my-r32/
Oh yeah that is another mod that has been done. I will post a pic of the remote upgraded coil pack setup. Though that said it still may be a problem. Actually to be honest it has started after removing the Rocker covers so may be the prob as they had to come off to do that. Will look tomorrow.
Do you know why the air flow meter is doing that.
Also is 185.5rwkw a good number for a stock turbo FMIC, full 3'' zorst, fuel pump and FPR on 11psi
200hp would be good or 200kw with a high flow turbo. Post up your dyno chart. What is happening to the air/fuel ratios? If it is leaning out at high revs/boost you could damage your engine. Have you tried turning the boost down to 10psi - does it make any difference?
I used to have an r32 a while ago and randomly when driving it would sputter along pretty aggressively
I would feel as if i was driving along normaly, then slam the brakes on, then hit the accelerator again. It was actually pretty dangerous and would annoy the sh*t out of me
I changed the AFM and it was all fixed
if the fault went away after you fixed the fuel pump wiring and then eventually came back then the fuel pump is the likely issue.
Add in that walbros don't like a lot of pressure and that there are plenty of dodgy copies out there and you are pretty much on the way to having it sorted.
I generally don't like the ex coil mods either. Been there done that, went back to splitfires....
No offense to you, but get a diffierent tuner, if he uses a Fpr to fix a problem, then he is out of his depth. firstly do a trouble code check, compression test(to check the motor is still good) and check fuel pressure.
No i will stick with this tuner as he has fixed the problem. It was a dodgy fuel pump. He is a very good tuner up here and has a very big customer list with fast daily driven cars that are very drivable.
Did this and checked the flow of the puel pump. At high RPM the fuel pressure drops to nothing replaced it with a 040 and is all good now. Thanks for all the replies.
Also the EX coils are going very soon. It was on the car when i brought it and my tuner has said to get rid of them and go splitfires. So this is happening. Thanks.
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
