Hallo guys!
I finish my car but I have many many problems with the stock ecu.
My tuner don't map it well. In easy driving the car is shit.
Many "cut offs" and other problems.
The dyno cannot meusure the power of the car.. with 5th gear and 6500rpm limit with 1.3 bar I see 620flywheel hp.
The strange was that the torque goes parallel with the horsepower!! :D:):D
I cannot understand why but it is very strange!!
I think that the torque must peak at lower rpm.
I will put the dyno sheet later if you want.
So I take the decision to buy an ecu.
Power fc d-jetro will work good for my specs?
I don't need to connect any afm as apexi tells?
Can I have lanch control with power fc?
I don't think that it nessecary for me but I would like to have it.
I did 60foot at 1.565 seconds!!
https://www.sau.com.au/forums/topic/239092-power-fc-d-jetro-for-my-specs/
S13 RB26DET
Engine
HKS [Pistons,Rods,Cams(272-9,32),gears,belt] Nismo oil pump, All gaskets Tomei, All studs Arp, 2x044 with surge tank and one intank walbro, all with earls fittings and hoses(2x6AN feed and 1x8AN return), sard fuel rail with sard 800cc injectors, os giken twin plate, gtr gearbox-diff-axles, 600x300x120mm fmic gtr style, 3,5" exhaust, XS Manifold with T04Z .84 and a turbosmart 48mm wastegate, ATI Race pulley, nismo mounts, oil rerurn, big oil pan
Not trying to be a smart arse but just plugging in a power fc wont fix ur problems... however a properly tuned and mapped PFC would suit ur setup very well.
1) idle will be as good as you make it, its in the tune
2) Same as above, a crap tune is a crap tune irrespective of the model of ecu, people get great results and great everyday drivability with AFM Power FCs and MAP D-Jetro FCs
3) You can have what ever a/f ratio you want at cruise
4) I think (not 100%) that only the FC Pro got launch control, so the D-J wont have it
Ive been following your build a bit and if im not wrong, ur currently using a pre-tuned replacement ECU
A Power FC D-J is not pre tuned, you cant drive ur car until you have the ecu properly set up.
A regular PFC comes with a kind of base map, the D-J does not, it has to be mapped from scratch.
If ur not happy with ur tuner time to find another
Oh and dont dyno ur car in 5th do it in 4th, closest to 1:1 ratio
Look at paulr33's PFC faq has loads of info on there will answer all ur questions
http://paulr33.skylinesaustralia.com/docs/...erfc-faq.htm#12
Thank you for your reply.
My tuner retune the stock ecu but I am not happy at all.
The car do a cut off as I said at 2500rpm often with light load and he cannot fix it.
He tolds me that at the cut off his emulator blinks!!
Also I am not happy with mafs... I hate them... I blow one because of wrong connections and they are expensive!!!
I also don't like to have 2 mafs and an ugle Y pipe in front of my beutifull T04Z!
My choice to stay with stock ecu was very very WRONG!!!
Many people here said it to me but I don't hear them :thumbsup:
Anyway I will go for power fc d-jetro as you say me that will work good for me.
But why some people say that d-jetro still needs an maf connected?!?
buy a Vi-PEC and solve all your problems...it has launch control, anti-lag, flatshift, launch control and data logging.
not much dearer than a D-jetro....but so much better. Better return to idle, faster processor laptop tuneable and software and full product support available.
dealers in Europe too
Edited by DiRTgarage
Because they are idiots, if you are after the other extras, and with your intended use of the car, i would fit a vipec(i didn't reaslise they were available in europe yet) or SM4
I still need aac/idle valve with power fc or now I don't need it?
For launch control I bought today GIZZMO!! I think that it is very good product and with gizzmo an power fc I will be ok!!
I have single throotle body manifold (JUN). Where to connect power fc map sensors?
the djetro powerfc (well any djetro setup) is reliant on the map sensor signal
and the rb26 djetro powerfc has two map sensors
on your car
1). are you using two map sensors
2). where are they connected (where?, location?, method?, in front of compressor?, after intercooler?, before throttle body?)
3). what does ETC, SENSOR SW CHECK show for PIM-1 and PIM-2 at idle?
4). what is set under SETTING, PIM VOLT
without answers to these you wont get your problem solved
and finally - you need a good tuner, not just install the powerfc and do power runs
you NEED to adjust the fuel and injection maps and trim the PIM if need be
I think with power fc you still do, i asked my engiune builder if i could remove mine, but he thought i was using power fc and said i needed it, but if i went to a computer like Microtech or something similar (and fairly basic) i would be able to remove the idle control valve.
i use fcon pro and i think i would still be able to remove it. but power fc maybe not as it uses alot of factory stuff sensors etc..?
because we love it? and i have nothing better to do at work.. which reminds me i may aswell go play some pokermachines and practice my double ups!
hearts hearts double diamond club?? usually does the trick!
Edited by Angus Smart
paulr33
I don't have the power fc now! I ordered it and I will have it in the following days.
So in your questions I can reply you when I install it.
But can you tell me where exactly to connect the map sensors?
DiRTGarage I cannot understand your problem!
You don't want to help me? Ok don't help me Mr Perfect!
Which advices I ignored?
You tell me to remap me stock ecu to solve my problems... I go to the tuner and he remap it..!
You tell me to change the stock ecu with another and I do it! I bought a power fc!!
I do whatever you say me! I know that you know everything about skylines and I do whatever you say me.
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
