  • Replies 44
Originally posted by zanda
Rian, just out of interest, what sort of hides did you use?
someone told me that there are special car-hides which have been chemi-treated to resist cracking and fading and that these dont go for any less than $800/hide.
hHi Alex my hides are lounge grade and are heaps cheaper like around $200 a hide good enough for me:D
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
