Not sure that's true. ACL make rings for Ross Pistons as well as other big name piston manufactures. Mahle and JE also use Total Seal Ring sets. Different size/application pistons from the same supplier will have rings sourced from different places.
Also Trent - Did you give Performance Wholesale a try for the rings as being Australian distributor of Total Seal Rings they can have almost anything made. Shoot me an email if you are ever stuck again.
Cheers
Marty
Martin your a legend... i did not know that. We use quite a bit of the the Total seal gear and i reckon the 300zx stuff i got for the RB26 trust pistons probably came through you via precision :P
I'm so busy at the shop i usually get the machinist just to add the components to the machining bill to save me chasing it up but of course i pay a premium for my lazyness..... I will drop you an email to save boring you on the phone and see if you can supply me in the future..
i figured out the spacer thickness
just a quick question :
the squirter make a (jet of oil) or (oil mist) , cause i would space and just offset the skirter abit to clear the piston skirt !!!
do i put it to shoot on the outside of the skirt or inside
i'm would go for the inside position !!!(red dot)
Blue : stock position
Red : option 1
Yellow : option 2
Red dot...just be careful of the rod clearance.
Riken rings are what im using on my JUN (cosworth) pistons in the current engine.
Cheers
Marty
These guys got some total seal rings for me a couple of years ago... I had to replace the rings in some arias pistons and they were a strange size... I was really happy with the service and can recommend them, they had to get them custom made (in the US I believe) and shipped and it all took about a fortnight
greg, is that engine also running argo rods :devil:
It sure is Marko, even has a head on it but no sump as yet.. hopefully will have it back tomorrow. The diff is set up, still waiting for the seals from Nissan was the news I got today.
it looks the goods greg on that flow bench!
i cant believe the turnaround on those seals from nissan, they're obviously in no rush
diff seals are overnight...i just ordered and recieved a set...??? Kloster Nissan in Newcastle...overnight from melbourne.
HAHA any nissan part 5mins...... the factory and warehouse is round the corner :devil:
i wish this was the case, its with gregs diff guy...unfortunately out of both of our hands
The diff guy's getting them, not me. Nissan dealer here can be slow at times, usually quite good though. As long as I have a sump back tomorrow I don't mind. There's a reef in QLD waiting for me on Saturday, it's gotta be done before then.
The manifolds don't look the goods though Marko, bolting them up is like doing some "unporting", even with a good cleanup inside.
Anyway... back to pistons...
Did I mention Wiseco's are good?
Cheers
Marty
Yeah Mahle make all the rings that come in ROSS piston sets for the RB engine and ACL also (because they are just a ROSS piston and Mahle own ACL now too) . JE use total seal in some of their applications but not all.
You work for performance wholesale don't you? Check with ROSS when you are back at work.
okay, im getting a rough idea of what pistons are better than others now. but when do you start having to go for the best eg. Jun or Trust??
im aiming at a max of around 350rwkw with a RB25/30. what pistons would be recomended for a power like this?(it will be street driven) JE or CP??
Wiseco. they run tight clearances, are quiet, strong, have a skirt coating and excelent rings. You can get a flat top to suit 25/30 that has a 22mm pin as well. I use them quite a bit. The Spool rods can be bored to take a 22mm pin no problem.
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
    • I'm getting PTSD flashbacks seeing that name again.  With my turbo swift, I got 1,500km of street use on a Jim Berry clutch before it exploded and took out my input shaft with it.
