  • Replies 251
Posted Images
sent my entry away to day
if car is a gray import(limited compliance) than you will be sv as per sup regs
cams is very out dated as far as class go for club level things imports are in the to hard basket as to many diffrent cars to work out
Just like a whale riding a wave into shore!
**Note to self**
Stop trash talking when you know even a stock datto 1600 will probably hand you your a$$
LOL nice one Bobby.
Do you think my car looks fat?
negatory mate!! Didnt think to ask either.. sorry :P
If ur super worried or dont hear anything over next few days let me know and i still have the # called me in my phone
