  • Replies 251
Posted Images
Mmmm, in that case ill buy some new tyres for the supra incase i really do need to take that and not the gtr, the current fronts are down to the belts and have to survive a victoria trip before this bathurst trip
Shame there's no class listing (eg who's bringing what)
Thanks for the info fellas, and how is day 2 run? (ie where does it start and stop up Mountain straight?)
sounds like some good fun...
Cheers
Michael
Edited by wrxkilla
Hey Michael!
Sunday - it starts umm....theres a sponsor sign which goes across the the track - which is on the top of a hill on mt straight, and then it goes up all the way up to reed park!
its awesome!
and its 1 car at a time up there!
Hey Michael!
its awesome!
oh that sounds like good fun.
I have some planning to do, give me a week.... :blink:
I'm going to be cutting it close, but still in at this stage.
I might drop them an email and see if I can book it and if the car is not ready get a refund or sell my spot.
Oil cooler is in, but leaking when under load.
Need to sort out an exhaust in the next week or so, and tune will be begining November.
Hopefully a visit to Wakey mid Nov and if all ok - Woo Hoo!
I think its 90 for the saturday and 80 for the sunday with 5 reserves.
Really dont know, to be honest, I dont even know if Ive made it....just sent paper work + money order and hope for the best haha
Yep, make the most of the weekend and do both days :cheers:
Try getting on contact with Robert, president of blcc
Bobby,
get ya arse into gear mate hahaha
Chris best thing to do would be to ring them first thing in the morning and explain where you're coming from, then fill in forms and send express mail with a cheque by the close of business tomorrow if there are still spots available :D
We can help sort out accomodation if you get accepted
Im not understanding it all either Bobbeh...
32 gtrs were actually sold here....but mine being a 33 gtst nugget...not sold here...with mild mods...technically i should be in class svd.
Then Adam was saying before that I can actually enter in 2D....as was discussed last year at the event....so Im gonna get in touch and find out!
SVD has some evo's and stuff as well
I got a few beds available for the weekend if your keen.. we do a B&B and will cost you $100 for the 2 nights.. i have entered already so ill be there for both days.. let me know asap on accomadation
Thanks
Ok, going off this I am definitely SV - Over 3000
Unless I can argue that larger Brembo's and discs are a safety feature :-)
http://www.cams.com.au/downloads/NSW/2194.pdf
Not really fussed though - not going to win, more for the fun of it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
