thats really unlucky mate, its wierd how 2 of my mates with 350z had drams this week aswell, one with full veilside had a hit and run (front bumper smashed, headlights cracked, and parts of the carbon fiber bonnet chiped scapped) other one got keyed just on the driver doors and back bumper.
i think them d*ckheads are just jealous or got nothing to do. real sad i must admit.
dam xtc, thats sounds real serious...
yeah shame people cant leave any sort of decent looking *different* car alone.
=/ when i had the skyline it was the same, but no1 went out there way to key it...
damage = probably respray panel, down 2 metal about 5mm wide @ widest point 10cm long, pretty pissed coz 4months ago i got the other side done tooo
SIGH
i actually went to have a look at it last night mr gazza, apparently its pretty bad, got quoted 5-6k for repairs paint etc. its nearly the same colour as yours but i think hes got custom paint. dont know about my other mate but its not as serious. have you got a quote for yours yet?
mmm i danno i parked my car out front of a primary school fresh painted qauterse come back see a huge key mark between the fuel bit and the door i was like WTF....kids these days need to find some better things to do lol if only they know how much it actually costs to paint a qauter panel ! lol
the day i put my vl in primer and parked it on the drive way it got bombed with paint ballons (like water ballons but with paint in) and i went to spray the car the next morning and had to re spray primer coz the car was paint bombed with pink blue green red black and they scratched every single window on my car as i just had them tinted about 4 days before that little assholes aye i wanna kill them and now the car is still in primer they dont touch it and it gets parked next to a alley way which gets tagged up on nearly every friday night and they dont touch my car for some reason
yeah, agree to all the above... dont see why KIDS have to do this kind of sh!t
i mean go to the beach n get wasted n go home.
=( finks cops shuld do sumfing 2 prevent it,
yeah my mates 350z got his door kicked in @ joondalup.
nah i aint got a quote yet... its bad, but probably get away not respray the door panel.. got a good mate who fixes that kind of stuff.
my old man had his brand new VW keyed front to back on each side and when we got it panel beated, the doors were all unsymetrical on each side and the interior smelt like paint- apprentice panel beater? :P , and there were no cameras to catch th p*^%k who did it. :banana:
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
