try envy imports. They recently bought a number of brand new RB26 heads and have been trying various different porting jobs and getting CNC programs done so they can now get them done on the CNC with hand finishing. I had a look at a few of the heads they'd done and they looked damn good. http://www.envyimports.com.au/contact_us.html 0408 637 489 Herman.
  • Replies 48
Im doing the same to my Stagea soon (and hopefully me lol!!)
have bought, and have got on hand:
Cometic intake manifold gasket
Cometic intake collector gasket
Cometic exhaust gasket
Cometic Head gasket 1.2mm x 87mm
ARP head stud kit
EPP 6mm viton Intake valve seals
EPP 6mm viton Exhaust valve seals
EPP Intake valve seats
EPP Exhaust valve seats
EPP Intake valve guides
EPP Exhaust valve guides
Q45 90mm throttle body
Greddy Q45-RB25 adapter kit
EPP clear cam gear timing belt cover
Tomei oil gallery restrictor orifice
Tomei hi-lift valve springs ~8.8mm
Tomei 256/256 pon cam shaft set
2x 700cc Sard injector external intake manifold setup
Ive been quoted around $1200 to $1500 depending on how far I want to go with the porting job, from Lewis Engines in Mt Barker Sth Aus.
parts have cost me exaclty $3000 AUS, from Sliding Performance (best dealer on SAU, thanks guys), and Erics Performance Parts (USA Ebay, when the u$a-au$ dollar rate was almost equal)
so all up its a $4000 to $4500 job, plus the retune and basic service stuff. say 5grand.
looking for big torque thru the auto and around an easy 230kw
lewisengines in sa do change over CNC porting which is handy, http://www.lewisengines.com.au/category25_1.htm#178
full pictures and shizzle.
Edited by URAS
Its nice to see a website like that with all the prices and info provided
i should add i havent used them. ive been thinking about sending a spare sr and rb26 head accross for them to play with, then we will evaluate it once we get it back.
Edited by URAS
They do have a reputation for their work over the past decade(s)
prices increase if you want extensive port work done though, from mild to wild apparently
talk to Darren Lewis for details
  • 1 month later...
Warlord, how'd you end up going with this? Did you get the head ported?
nar not yet still collecting info ive blown a clutch since this post started and still saving cash, im at 3k now and still need more i want a exhaust manifold,larger intercooler,throttle body as well so next year is looking good.
plus ive got a baby on the way so ill have 2 under 2 next year so it will be the last mod ((yer right))
Haha fair enough man. I just finished pulling my head off, sending it down south to get ported, angled valve job, new seals, new springs etc etc. Then chuck the Poncams in, squeeze 20 pound into her and try to see whether i can finally get my car running with camshafts haha. Ill let you know how i go.
Edited by PM-R33
who's doing your head.
Ported and polished, increase of 30% flow to 255cfm. You can increase up to 270cfm but costs an extra $500.
Pressure testing the head. New seals. Angled valve job. Installing my new springs and then decking the head. So pretty much a full reco job.
$1050 plus freight of my head.
I might give them a buzz and see how much extra its gonna cost to install an oil restrictor to the head, figured i might aswell do it while its off. Going to do some more reading on it though.
If that pic of the RB head in the Lewis engines link is anything to go by it seems they remove the quench pads. Meaning your chamber volume will be increased. So you will find you drop comp if your not building the bottom end to suit.
May want to confirm chamber volumes are the same or near the same as stock if your putting the head back on an already built bottom end and not going to a thinner head gasket.
What's a quench pad?! That's a new one for me lol.
Have a look at the link to Lewis Engines in this thread.
Now look at the pics on the site of the chamber for the SR20. Now Look at their RB head. In stock form the RB head is smilar to the SR20 head. You will note that the RB chamber is round. The SR20 chamber is not round but has straight edges in the chamber running down its perpendicular. This formation essentally forms a quench pad in that on the upward stroke of the piston the pad compresses the mixture into a smaller volume into the middle of the chamber right underneath the spark plug and in doing so is said to aid swirl in the cylinder for a more complete burn.
Others argue that the pad - due to is straight ridge it forms in the cylinder - increases the basis for a 'hot spot' under compression leading to detonation.
If you look back at the other thread Shanef posted up a little while ago with pics of his JHH head you will note that JHH doesn't remove the pad but they lay it back towards the cylinder wall in a way that takes away some of the sharpness from pad. In this way they have attempted to keep the pad to keep up swirl in the cylinder but have modified the pad in an attempt to remove the potentional for detonation the pad can cause.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
