r32 gtst with front end damage some idiot pulled out at the lights without looking
str8 in front of me shattered just got it registered the day b4 now its time to get rid of it im sik of looking at it every morning knowing i cant drive it
it has only 85000ks on chassis r33 interior rb20det was told it has internal work though havnt opened to see and has after market turbo
boost controller boost gauge cd player new 3" zorst turbo back full drift suspension seems to be no damage to steering or anything
though is hard to steer as gaurd is touching wheel. the car was running sweet b4 accident car was well maintained and serviced every 5000k
interior is in vgc windows are all good aswell no cracks or anything will sell with bronze 17" work rims as pictured on rear
i am also selling the gold 18's and will throw in a set of potenza semi slick tires to the buyer
have had car quoted to repair will cost between 2-3k painted
is good for parts or repair
also i am willing to trade this for a 7 seater 4x4
want to sell car complete though if dosnt sell will part her out
make me an offer
https://www.sau.com.au/forums/topic/239779-r32-gtst-front-end-damage/
im in sunshine vic
min 3k with bronze work rims
1100 for 18" gold work rims with potenza tyres
car owes me alot more and is worth more in parts
if you want to look at it give me a call 0401787434
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
