The only thing you have to worry about, apart from the tyres sticking out of the guards is rolling diameter.... you can go +15mm or
-26mm
Pages 10 and 11 has the info.
http://www.transport.qld.gov.au/resources/...r_vehicles2.pdf
and to calculate u can use..
http://www.dakota-truck.net/TIRECALC/tirecalc.html
I might be totally wrong and probably am lol but i didnt think you were allowed to increase overall track by more than an inch. Don't even know if the GTR rims will do that, but might be worth looking into...
I was thinking of doing the same thing to my GTT so would be keen to know if it is ligit!
PS drift barbie - I have an aftermarket ecu, what were u wanting to know? and yes i know u werent asking me :P
The problem you'll have is that they do protrude ever so slightly from the front guards.
lowering, camber + skinnier tyres will fix that :)
But yes as someone mentioned above, as long as OD is not more than 15mm and wheels/tyres do not sit past the guards you are fine. This is for QLD.
You will however find a large majority of hardcore wannabe drifters think of you as a softc*&k for asking the question though because to them if its not hella flush (wheels stickin 50m outside the guards) you are an epic fail.
I've seen plenty of 34GTTs run 34GTR wheels....legal or not legal depends on the mood of the day. I would class it as very mildly illegal.
yeah pretty sure you can't go wider than 30mm from the standard tyre,
bingo...
You can increase the diameter of the rim as far as you want as long as its no bigger than the original OEM delievered diameter including the tyre...
The statement below is true also when refering to the above line... This is the max varience allowed when changing the profile of the tyre to suit...
you can go +15mm or
-26mm
col, i think he may have been meaning the width of the tyre, rather than the diameter. the widest you can go is 1.3 times the widest option stock tyre that was available on that car. so even if the car came with a widest optional tyre of 225 you could still run 285 tyres (1.3 x 225 comes out at 293 so you could probably get away with 295s)
the other thing you have to take into account is that changing in your track. you can increase the track by up to 26mm, but can't reduce it at all. so that means that gtr wheels won't actually be legal because they have a lower offset. and before people start saying that they came on the same generation car, the gtr runs different track to the gt-t. the front is the same but the rear is different (it's wider), so putting the gtr wheels on will reduce the track. however if the gtr is listed on the same tyre placard (sticker just inside the door) as the gt-t then you could get away with it.
Sorta, I didnt explain myself very clear... But in short you can run 17" rims on a car that came out with 14's if you want...
As long as the overall diameter of the tyre is no bigger than the OEM product...
As there is slight difference always the DOT came up with a suitable legal variance...
you can go +15mm or -26mm
I stated 30mm, meaning an R34 GTT can run up to 255 without being much of a problem in terms of sticking out etc...
That said however it depends on the size of the rim as the profile size will change the first number factor...
As for width yes there are some loop holes as to running even wider rubber, however there are other factors that usually stop you from doing so...
You cant run rubber wider than you guards, if it sticks out its illegal (hence offset of rims is so important)...
Also I should point out the rubber sticking out is really down to the kindness of the officer as to whats right and whats wrong. Ive heard of a VE GTS (stock rubber) being booked by police in QLD for having rims and tyres that are aparently illegal by DOT standards. These were factory fitting rims and tyres, so even if legal cops can still put you through the hoops if they want...
The legal line is quite clear in here as posted the other week...
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
