Item:
R32 Skyline GTS-T
WRECKING complete car
Bonnet -$ 100
Boot lid -$ 150
Doors -$ 200
Front Guards -$100 each
Front Bar (needs Repair) -$20
Tail lights (perfect condition) -$250 pair
Head lights -$150
Front Seats (Perfect Condition) -$250
Back seats (Perfect Condition) -$200
Dash (minus 1 vent) -$200
dash Gage cluster (comes with BLUE LED) -$150
Rear windscreen already removed with tint -$300
ORIGINAL Front windscreen -$300
side rear windows - $100 each (all windows will be removed if u want them)
Diff -$200
Coilovers less than 1 month OLD G4's - $1000
+MORE
if u need anything text me or pm me i need this stuff gone to start my other car
Brisbane - Northside
Item Condition:
GOOD!
Reason for Selling:
Wrecking
Price and Payment Conditions:
as above
Extra Info:
Pictures:
ask and i can pm more to you
Contact Details:
Kurt 0447 619 249 ANY TIME
https://www.sau.com.au/forums/topic/239782-wrecking-r32-gts-t/
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
