Nepean Hwy. Not a good place for a modified car. Cops out in force and defecting regularly, particularly during the warmer months.
Some of the roads out the back of Healesville (not through the Black Spur, through the other side of Healesville) are awesome but they're likely to make you a bit carsick. No straights, all corners.
QUOTE(iseekool @ 13 Oct 2008, 01:11 AM) post_snapback.gif- Rye - drive down the road that follows the coastline (can't remember the name) - also go to Arthur's seat.
Some of the roads out the back of Healesville (not through the Black Spur, through the other side of Healesville) are awesome but they’re likely to make you a bit carsick. No straights, all corners.
Yep. Nepean Hwy, but when you get to Mornington (heading south) make a right turn at Beleura Hill Road, then make a left turn onto the Esplanade and follow it.
only if you are a passenger. think bout it. when have u ever gotten carsick while driving? its because you tend to lean INTO teh turns when at the wheels while passengers get thrown away to the outside. really messes with their balance centers. therefore, to prevent carsickness, lean the same way the driver is leaning - into the curve
Another great one is ether Eltham-yarraglen road or skyline road (lol). A good drive from the west is to get on the ring road, get off at Greensborough and drive along diamond creek road, then wattleglen road and then either of the 2 above. These lead to healesville.
Funny thing you mentioned "Skyline Road" because there is a road that connects to it called "Breakneck Road"
:laughing-smiley-014:
If you want to drive out to it, I think that the Korumburra - Warragul Rd is pretty good, especially heading North but is safer going south & eases you in.
I used to have to deliver stuff periodically for Reece from Pakenham to Leongatha & ALWAY took this road.
It has some tight blind turns with shear drops and no Emergency lane (watch out for those bumps on the outside, they will bounce you 1/2m towards the rail), sweeping high speed bends, inclines, declines, almost-hairpins, mostly 80-100kph limit... Just try to keep it above 60kph :D
Oh, and if you catch it with some light mist, be very careful - those 50m+ vertical drops with only a pissy little guard rail on the side of your lane to stop your car (yeah, right) would put an end to your driving days I would think... :)
Edited by iamhe77
Im from the surf coast my driveways 50m from Great Ocean Road. Recomend start from torquay head down to lorne turn right of the main drag in lorne before the cumberland hotel (the old big building on the foreshaw that used to be painted pink) and head up to erskin falls. great drive and falls are fun if ya wanna check em out.
then you can either keep goin past the falls inland or turn back to lorne and go to apollo bay. Be careful though the trees have all day shade on some sections near the falls and there is one nice wet spot on a corner because water doesn't evaporate and a mate of mine lost it while we were driven there and i watched him slide down an embankment. it pays to watch the surface!
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
