  • Replies 180
Posted Images
i wasnt doing the best driving but i was having plenty of fun :)
i want to see some pics :)
lololol
id like to see the new rims on there with stretched tyres and massive camber and THEN see what you can do....
Nice improvement during the afternoon ^. I'd hazard that you were going around maybe faster that I was. Definately a lot cleaner.. ;)
Great fun.
Awwww thanks :) Yeh you guys were having heaps of fun just trying to drift :)
Not me, 4wd and drift doesn't really go in the same sentence.. worked my way up to 7k launches though, pity I couldn't keep it straight afterward.. I took a few pics, will throw them up in a few minutes.
Was an awesome day; I can definitely say I didn't improve my driving skills today, I was just having a bit of fun. It's was way too hot to learn anything!
Nice work [ADORAA], you were getting damn fast by the end of the day - way faster than me, but that's a given!
I'm ripping the videos off the little car camera now; some of them are pretty crappy, but there are a few decent clips worth watching I really with the damn thing had a wider lens on it; can't see anything in some of these clips.
post-16250-1229160353_thumb.jpgpost-16250-1229160407_thumb.jpgpost-16250-1229160424_thumb.jpgpost-16250-1229160434_thumb.jpg[
attachment=196594:IMG_0720.jpg]post-16250-1229160453_thumb.jpgpost-16250-1229160463_thumb.jpgpost-16250-1229160471_thumb.jpgpost-16250-1229160481_thumb.jpg[at
tachment=196599:IMG_0726.jpg]post-16250-1229160503_thumb.jpgpost-16250-1229160526_thumb.jpgpost-16250-1229160537_thumb.jpgpost-16250-1229160548_thumb.jpg[atta
chment=196604:IMG_0731.jpg]post-16250-1229160573_thumb.jpgpost-16250-1229160583_thumb.jpgpost-16250-1229160594_thumb.jpgpost-16250-1229160604_thumb.jpg[attach
ment=196609:IMG_0738.jpg]
This proves I am no photographer either..
Edited by heller44
yeah same
the guy that was taking pics this arvo said that he had 1300 pics....
yep i got them on my pc now.
ive just finshed sorting them according to cars.
Now to upload them.
Ill put them on photobucket and ill give out a link to each car and their pics.
The photographer name is Jake he will be photoshopping the really good pics sometime this week. Ill be sure to pass them on to the owners of the cars.
those instructors were downright impressed sam
i think everybody else was aswell lol
cheers,
left a bit early my tyres got a lil bald :) slippery surface out there lol,
had a wiked day thanks to my girlfriend for letting me have the afternoon off work and paying for all my tyres n fuel n fines n stuff
cheers,
Sounds like a keeper! =D
