hey nath
there have been some tinting posts floating around that says that it is legal to have 20% for the rear window and 35% for the sides
I am not putting in my preference yet - but is that a legal combination?
One more thing - they put a little tint-a-car sticker once they have finished right? Will that mean that when the coppers complain and u show them u done it at a legit place they will leave u alone? hehe
no he doesnt put the sticker on unless u want it, mainly coz 99.9% of people take them off anyways
basically 20% is illeagal if its on your windscreen to your rear window or on your p*nis its illeagal, 35% is the darkest legal, windscreens CANNOT be touched and ther is no combination which is legal, 35% all round is the darkest legal you can have it
20% is very dark, it looks awesome but depends if your willing to sacrifice being defected :P personally i got 35% and find it juts nice
oh and if you get the illeagal stuff u dont get a receipt because basically 'he didn't tint it' if you get the illeagal stuff, he will still warrant it if it goes stuffed but otherwise you get no documentation, wheras with the 35%$ u get a writeen lifetime warranty
Scotty (Coupe)-10AM (???)
kC king_kw13's Friend (4 Door)-11AM (???)
Mo king_kw13's Friend (4 Door)-11AM (???)
hey i havent heard about what type of tint these guys wanted so i have to just put them all down for 35% (legal) as the guy needs to know today to order them, if you guys want illeagal please CALL ME on 0411 50 54 58 before 2PM this afternoon and tell me
cheers guys
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
