why would you buy the S14 if you knew you wanted a Skyline? :P
i agree with above posts in regards to them being a great car, but if you knew you wanted a Skyline... hhrrmm can't go past RB love :)
Impluse buy, got a little excited at the prospect of a first nice car
https://www.sau.com.au/forums/topic/240232-big-mistake/#findComment-4195574
anyway, you don't want passengers in the back, too much weight and they talk too much!!
Yeah most the time it's ok but, I was giving a lift to 2 friends the other day and 1 of them was trying to fit in the back. It was so bad he decided to get out and drive his commodore instead. :P
https://www.sau.com.au/forums/topic/240232-big-mistake/#findComment-4195589
Lol this is still making me laugh. Why not sell the silvia and buy a line im sure some drifter would want it...I will give you $500 :P and im willing to go to $250 Final offer lol
Will eventually, can't afford too right now, Insurance and stamp duty and yeah...
Edited by gersfan
https://www.sau.com.au/forums/topic/240232-big-mistake/#findComment-4195596
i wanted a 180sx, but am happy with my skyline :P
the s14 is HIGHLY under rated!
as far as looks, the rear end IMO isn't crash hot but series 2 front end is the bomb.
its easy to get good HP out of the s14's and they can generally look sleeper-ish, (compared to s13/s15)
is urs gen 1 or 2?
https://www.sau.com.au/forums/topic/240232-big-mistake/#findComment-4195633
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
