Group Buy: Skyline Power Steering Cap Cover Plates
Hi all,
Over the last year and a half I have been engaged in the rebuild of my R34. During this time we have spent a lot of time and effort adding small touches here and there to make things a bit more unique. Some are specific, and others are more generic (i.e. for everyone)
One such part that we came up with was a cover plate for the R34GTT Power Steering Cap. Even though the standard one was in OK shape, I found that it was a "dull" point when compared to the rest of my engine bay which is mostly filled with shiny bits n pieces. So as per usual, the spanners were dropped and the drawing board was manned. The design brief was "simple, easy to fit, and attractive". Once the design was finalized, Ann Harris @ K-Bar was contacted to do the hard work - as always she delivered with fabulous results.
Business Details:
Ann Harris
K-Bar Laser Etching
http://k-bar.com.au/
All our initial designs involving this technology were sent to numerous suppliers around Australia. Ann came back with the lowest quote from everyone, and was happy to assist with material choice, artwork and other recommendations. In total, around 20 suppliers were contacted and these guys were by far the best deal for our purposes (i.e. once off designs and productions)
What's on Offer
For those who took part in the R34 Fuse Box Plate Group Buy, the quality of the item is already known... the photos below show MY OWN version of the Power Steering Cap Plate - the final picture is the artwork that Ann has done for me, so I can offer it to you guys. Please note, even though I am 99% sure that this is good for ALL Skylines (dimension wise), please check by taking a ruler to your engine bay!
The third picture is the artwork sent to me this morning by Ann - there are a couple of designs there to choose from. I am under the impression that the numbers required for this GB are TOTAL UNITS, not UNITS PER DESIGN. So mixing n matching the order is fine.
imgp3285al3.th.jpgthpix.gif imgp3287jo4.th.jpgthpix.gif fromanngt3.th.jpgthpix.gif
Pricing
Ann is still finalizing the quote based on 0-10, 10-20, and 20+ units.
Just like the last group buy, pricing will include 1x Plate, Postage, and maybe a little surprise (not guaranteed)
GROUP BUY END DATE AT THIS STAGE IS: 15/11/2008 (or earlier pending public interest)
Specifics
Material: 3mm Metalgraph Plus (brushed stainless look)
Etching: All etching will be in BLACK (no exceptions)
Holes: No mounting holes will be needed; two small dabs of adhesive are all that is required for mounting
Care: Minimal care is required, this material is scratch proof - an odd wipe wouldn't hurt though
Interested pending price. Won't want to pay much for such a little thing :dry:
Is one of the bottom 'GT-4's supposed to read 'GT-T'? I would prefer that.
OK quote has just come in from Ann...
10 $18.00 each
11 – 20 $17.00 each
21 – 50 $16.00 each
51 + $15.00 each
Please note that the above pricing includes everything (choice of design, and freight). From time of order being placed to delivery, expect 4 days (going off last Group Buy)
  • 1 month later...
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
