Hi All,
Just bought myself a new car, the only problem with it is that it smells of fuel when driving sometimes, i thought that it might be engine related, but after getting the engine checked, etc. it was fine.
I filled up fuel this afternoon for the first time and noticed that the fuel restricter could pull right out, it wasn't in properly and the actual rubber seal is gone, could this be the culprit, i am pretty sure it is, and where can i get this fixed?
thanks
Kris
https://www.sau.com.au/forums/topic/24030-new-skyline/
i think he's refering to the restrictor that reduces the size of the fuel opening so it only fits australian unleaded fuel pumps!!!
have seen similar issues with my filler, get alot of gases coming out when i first start the car, once on a hot day after filling it up, i parked and fuel actually came out and flowed down the inside of the guard and went everywhere! was even on a slop!!!
https://www.sau.com.au/forums/topic/24030-new-skyline/#findComment-514652
You could ring up one of the many compliance shops around, they should have plenty in stock. The restrictor is put in by them, they don't have them in Japan so it's probably no good to ask Nissan for one (although they might have them for other cars that might fit the same, like 200SX).
Should be a couple of bucks.
https://www.sau.com.au/forums/topic/24030-new-skyline/#findComment-514715
thanks,
well i doubt it is the cat being gutted, i will find a compliance workshop to do this fix for us, thanks
I have posted pics of my car
it is a
1994 R33 GTSt
82,000 km's
Rebuilt gearbox, with short shifter
heavy duty clutch
APEXi exhaust
GTR Bodykit
Bilstein shocks
It also has that cool feature where the "SKYLINE" lights up :P
Kris
https://www.sau.com.au/forums/topic/24030-new-skyline/#findComment-515560
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
