How much work is installing water-air intercooling in a stock R33 s1.5?
I have to cut the front bar to get a fmic in, so maybe water with the heat exchanger where the stock smic goes will be asier, no cutting.
The autospeed article http://autospeed.com/A_107760/cms/article.html (might be subscriber only) makes it sound easy (don't they always), and some of the bits are on ebay or at http://www.frozenboost.com.
Z
https://www.sau.com.au/forums/topic/240375-water-air-intercooling/
Being that the air you are tryong to cool is already at the front of the car, a water-air intercooler is an unnecessary complication. Did you know that an easy (and cheap) upgrade is an r34 gt-t sidemount intercooler. It fits in the standard r33 spot, and is good for +200rwkw
I think most people decide that the extra weight and complexity of a WAIC is not worth it given that there are plenty of cheap air/air IC kits available .
I've seen nice things done with a pipe kit and a stock GTR IC , throw in a GReady type inlet manifold and it solves a few more probs .
A .
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
