i had 230 ish and that was wheelspin delux!
no point going > 250 ish without awd imho
good luck! let us know how it goes!
its partly throttle control, brand of tyre, and width of tyre
Cubes has 300 and can get enough traction
and now i have 255x17x40 mine doesn't brake traction nowhere near as much
  • Replies 143
haha nice work man, ill see ya at Willall on Monday aswell, My car's done now just waiting for monday...
280-300rwkw here i come
Cool mate what Turbz you running now? I will be dropping off car at 7.30 and should be back there by 12ish be good to see your beast there also good luck with it mate.
I must admit i might have to sus out my suspension, beacause its not liking grip in first even with 265 Hankook V8RS rubber and 200rwkw. Wheel spin is fun tho! :D
268rwkw I had no issues getting the power down once I dropped on a set of better tyres.
300rwkw is a little harder but it still hooks up well and is quicker up and rolling even when it is spinning/bucking around a little than when it was hooking up and making 268rwkw.
Low profiles = FTL if you want to get the power to hook up. You need preferably 16" with a bit of a side wall or at the very most 17" no more.
I ran around on a set of wide 18's and they were useless for straight line grip compared to the 16's.
Gt35r with a .63 rear, should see a good kick in the back about 4k...laggy i know but i've had a responsive turbo, now im wanna pull some good power and see what that brings.
Can i ask what size and what brand your using joel? I'm keen to put stockies back on it for a bit.
yeah, you got a point.
i had 19s with 245/35 s, not really a good choice in tyre/size.
i learnt my lesson in modding the 33, one of which, BUY JAP RIMS!:cheers:
oh, and thrttle control? whats that? :D
jks
yeah alot of people assume the bigger the tyre the more grip! but as cubes said it's not the case! i don't know if anyone agrees with me but the standard suspension seems to have the most grip off the line! has something to do with weight transfer i think
Edited by nos man
It's a catch 22 sometimes, Squat is good for weight transfer and dampens the initial bang of the driveline, but squat can also induce excessive camber which can leave less tyre off the road. Having softer, larger walled tyres means the tyre doesn't follow the course of the squat as much leaving more tyre on the road. Low pro's are fantastic for the hills for turn in but wack for straight line especially in a 2wd. (as said previously)
hence why we used to run 90/10 shocks on the front & Mickey Thompsons on the rear for drag racing back in the day
yep thats why i have gone to stock wheels but with good tyres, i used to 19's with 265's on the back and they just wouldnt give traction, i have red many of articles in magazines wihch were written by Martin Donnin stating standard suspension is the best for the drag strip, so thats why i have kept mine in so im hoping my new power will be more traction friendly
Very much looking forward to seeing your car back on the road when you get back dan.
mm good result!
gotta be happy with that!
fun times ahead!
Yeah thanks car feels excellent, very smooth linear power. Second gets a bit of a skip along when it comes on to boost. :D
Nice...
Now for some cams to pick up ~20-25rwkw on the same boost and then 2-3psi more boost and you should get damn close to cracking 300rwkw. :D
Cheers Cubes.
Nice and safe on the Standard bottom end at the moment. It's good to know theres still more left in it if need be down the track.
Impressive results on a mainline dyno there Lee, you should see 265-270 on a DD machine.
Im going back to the drawing board, Wastegate was WIDE open but still pumping close to 20+psi. So ive decided to Go external Gate modded onto my DMAX manifold so i can regulate boost alot better. I could just wack on a .82 rear with a larger internal gate but i want to retain as much response as i can get my hands on so i'm keeping the .63 with looked fairly responsive and going external gate.
Much appreciated to Martin and Mark for the help. Top Blokes.
EDIT: martin seemed to love my setup, i was a bit unsure about the size of the bastard. :D
Edited by Ryanrb25
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
