SOLD
boot lid
front seat belts
indicator lever
tail lights
transmission
centre vent
fuel pump
coilovers
diff
17" bronze work rims
parts are going like hotcakes
if people want stuff they better be quick
  • Replies 51
selling engine complete not seperating the ecu
turbo, actuator or anything else off the engine
would rather sell someone the complete package ready to drop in and go hard
and engine price is negotiable
What sizes and offsets are the 18s do you know mate? And if you wouldn't mind throwing one on your bathroom scales (with a tyre on is fine) and give me a weight?
Are you negotiable on these? I'll need to have TNT collect them and ship to Qld. PM me if you prefer.
bilstein coilovers are sold yes
rims say something like +32 18x7.5
dont have any bathroom scales mrs says she dnt like weighing herself lol
but id guestimate somewhere round 15-20kg with tyres on
they feel pretty light weight
coilovers sold too me!! :wacko:
can vouch for these parts, got a few parts off him and all great!! free bump!
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
