Oh on the topic of Red R33's, there is one going round, usually cardiff/glendale etc with the plates JE-33-SS or JE-55-SS or similar.
And where can I get some Skylines Australia stickers?
Edited by -Jimmy-
hey,
good thread mate, should definetly be a new club. i drive a stock grey 33 GTS around cardiff, lambton, wallsend area. well it has a stereo and exhaust.
one of my bosses drives a 33 4 door turbo, can hear it for ages on lunch when he goes up the road.
white and black 33 keeps goin past my house, big dirty intercooler hangin out the front of it, loud as all shit
so yea, a wave or flash would be good and respectful to newy and cc line drivers, cant wait for a club to be made
wen u join the NSW club, u get a choice of a sticker, other than that i wouldnt have a clue
cheers,
I make em for the NSW club members... unfortunately I dont usually keep enough stock to sell them to everyone else (I pay for them up front myself so i'm too pov to buy too many)... could probably do you a long URL one if you wanted though, I'v got a few of them atm.
On the topic of cruises, I'm going on the sydney pizza cruise sunday arvo... will be leaving from wallsend if anyone wants to tag along :D
Spotted a white R32 in Tafe carpark, dark blue R34 4door at Mayfield, red R34 with NT plates along Turton Rd.
On the way home from uni, along Newcastle Rd was an black R33 plates BLA33K. Gave hazards flash, got a nod back xD
hey Casey if you decide to come on the cruise I can give you your 'stuff', am actually picking up your shirt from the merchandise dude so I can give it straight to you :banana:
(btw ppl there's a thread about the Pizza Cruise in events, if anyone was keen but didnt know the details)
I waved to 5 skylines today and got no waves back. Felt like a dick.
Spotted
White R31 GTS1 just after kooragang
White R32 4dr near the QUIX at lambton (female driver)
2x White R33 GT-R (one in kotara, one .. i duno somewhere on the way to the airport)
Grey R33 GTS-t with painted black stock rims just past the airport (i think you're rad!s on ns.com?)
Grey R34 GT-T with white buddy clubs around Town.
-Jimmy.
Edited by -Jimmy-
Heya guys.... Saw a nice black 32gtr last night driving through maitland, Had huge deep dish rims, very tidy... waved, got a nod back. older guy....
I also see a a black 33 gtst on way to work in newcastle every morning... sk33ar or something number plates... dont get a wave back so have stopped waving... kinda look like a tool doin it every mornin!...
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
