what tafe was that?
nice white R33 skyline going around cardiff some nights, and this mornin GON33E, big dirty inter cooler hangin out the front.
also light blue and black two tone R32 gettin around cardiff, i think its a green p plater.
spotted Jason this morning at around 9:30 driving towards erina over the punt bridge i think its called.
Was staying at a mates place all weekend and had to drop the keys off at their work at green point.
I spotted a black/grey R32 with the same headlights as mine, with them turned on also (I had mine on too) in Kotara this afternoon. I waved but got nothing back >_< like usual.
Also spotted a MINT Black M35 Stagea coming out of the Cardiff Industrial Area, can't remember the plates now.
dude ur stalking me! hahaha, were u in the line??? cuz i didnt see ya :ninja:
Not sure if anyone's spotted me yet,
Grey r33 series 2, black rays engineered volk rims, 4" sideways mounted cannon,bowers suspension sticker on back window.
What meet up? The weekly Thursday Night meet up?
There's no meet up point for Newcastle people because no one ever comes from Newcastle.
Sydney people meet at the truck stop and the central coast people meet straight up at fountain plaza.
Haven't spotted you yet James (Grey R33), no one except Jay has spotted me ;)
Where in Newcastle/Central Coast are you?
I spotted a silver R32 coupe going up towards John Hunter this morning. I turned off at Carnley Ave so I couldn't follow.
Edited by -Jimmy-
Newcastle is the suburb, so right in newcastle lol.
Do a fare bit of driving out to wallsend/sandgate and thornton so yer.
Also would love to catch up with some fellow skyline owners in newcastle to get to know each other whenever we can organize a time... Finally getting my skyline back from the mechanics on Monday they've had it for 4 weeks :action-smiley-069:
Cheers James
Edited by na beast
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
