YEAH IM HERE!!!!! hahaha yeah its off the roads still. all i need is the drivers side guard and its done ...... ill post a pic of it atm in its dusty state :cool: just so you can all spot my skyline in my garage seeing as its been there for 2 months
This is how the skyline is going at the moment for you guys that haven't seen it out for a while. Ive got all new parts and all i need is the surround for the front bar indicator on drivers side, also front driver side fender.
the rest is all there except underneath the hood. Its been pushed back about 8cm but i have the radiator support
Spotted!
LOL
spotted 2 R33s yesterday morring around a 11am
both on the freeway
white R33 serise 1 non turbo * southbound*
gun metal gray serise 2 turbo * northbound*
Spotted andrews and jadas car.. at their house.. and drews car too...
also spotted sam916 at ourimbah this arvo.. was in the gf's car so u wouldnt have reconised me!
Spotted MY33RM at Glendale Macca's, very nice car.
Yeah this thing is mint.
It's a 40th Anniversary one, purple isn't it? Or am I thinking of a different car...
Edited by -Jimmy-
spotted a r33 4 door on manns road west gosford at 10am, was a girl driver and she let me cross at the zebra crossing unlike everyone else!
THANK YOU!!!
Not sure of the 40th Anniversary bit and it was more of a maroon.. but it was mint
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
