suspected broke diff on way to work tonight, not happy jan......
any ideas of best place to take it to get repaired in Newcastle
That sux mate, really sux. If i was you i would do the ring around for quotes or limp it in if you can. But when i busted my diff in my ss many years back these blokes were the best price.
http://www.yellowpages.com.au/nsw/broadmeadow/newcastle-gearbox-diff-pty-ltd-11858623-listing.html
I ended up selling the car so i cant comment on the work, but they were literally half the price of the manual transmission factory just up the road.
A bit off topic for this thread but need to do it. Spotted a blue s13 silvia in Lake Munmorah this arvo around 5pm. Pin dick was doing AT LEAST double the speed limit in a 50 zone after cutting me off to rip a shitty skid in front of me. He then proceeded to take both corners i saw him take on the wrong side of the road, one of the corners had a car coming in the other direction. All this while kids where playing on their pushbikes on the street. I know nobody on here probably knows such an idiot, but IF you do please pass on kindly this- they will be getting my size 13 all over their car to decorate that nice new paint job with.
thanks for the info, only thought i had done something to the diff, when i got to work and reversed park noticed a winding sound only in reverse, found a hill no rev's and rolled backwards, came to the conclusion sticky brakes, had them check about a month ago, still got 10,000 km on pads and disks, but ABS light on, havent booked in to auto electrician yet,
Lol I know, my 34 is loving the cooler weather at the moment.. Let us know the next time you are heading out, keen to go for a drive that doesn't involve me driving all the way to sydney just for a cruise..
Yeh being in there at night is asking for trouble. Went in there with my girlfriend two nights ago to chill out and watch the waves, I hoped it would be pretty empty on a thursday. I was wrong. The whole foreshore area was packed with commodores and falcons (with the odd silvia, lancer or daihatsu charade). We were there for about 5 minutes before a couple of tools in a VZ ute and an old statesman started redlining their engines in the carpark - so it was no surprise when two paddy-wagons showed up and started doing laps of the area.
The same calibre of people usually gather in the carparks of Westfield Kotara, Charlestown Square and Glendale shopping center for late night thursday shopping. Apart from that I'm don't know of any regular gathering spots. I try to avoid them though, with good reason.
Back on topic, I spotted a maroon 33 gts-t in Kotara yesterday, and a few days ago saw a bright purple 33 with a 34 GTR front end (near ausgrid stadium from memory?)
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
