just letting you newy guys know i have a set of wheels for sale
http://www.skylinesa...mags-2-of-each/
also spotted neat r31 GTS1 in cessnock
Put it in our Newcastle thread mate :)
White 34 on the back of a tow truck at Cardiff
I hope mine is still in the shed :P
On that note -
Spotted a champagne 34GTT (Didnt know they made one that colour) near bar beach
Spotted a white 34GTR near the self storage joint on Industrial hwy
Spotted a white 35GTR at Super Cheap Auto in Raymond Terrace (Kurtis reckons he was there for a pod and boost gauge :P )
All of this was on Saturday.
red stagea at kincumber on the weekend, chick driving
Ha ha ha that was my wife. She stole my car so now I have to drive a 323. All because the pram fits in the back better!
Been spotting heaps lately, should really remember to post :P
Most recent one is the silver 33 with black rims and chick driving through Tomago/Heatherbrae.... Judging by the exhaust i am guessing it was N/A
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
