Spotted T4NK down in sydney last night, heading north I think. Was a BB R34 on white rims, with an offset plate anyway!
haha yep i was on my way home from work, then i had to go back to manly to pick my dad up... where u in the bayside blue 34 that i passed on the pacific highway just after/before Turra?
Spotted a dark blue 33? (I think) with white mags at Wallsend this arvo
Just a word of warning if I see you driving again like you did today I will report you to the police.
Roundabouts are NOT for drift practice and a super loud exhaust does not make your car go faster, it only makes you look and sound like a tool.
Tank, is that your gtr parked...well was
Parked next to my i30 at payment fitness?
um, im not sure, i go to plannet fitness at West Gosford, if that was where u saw it then yes it was, white on blue, looks like a mirror atm, waxed it like one of my french girls.
spotted a maroon R32 the sarvo at south kincumber..... didnt get a wave back :/ always akward when that happens..... haha and the misses goes who was that LOL
and a black R32 going up the central coast highway going passed avoca drive on saturday i think.......... either high 2nd gear or high 3rd gear on full boost did sound pretty tough as you went passed!
Clean your white wheels tank haha
Yeah was your car!
i cleand them last saturday....... i clean them drive 50km they are black again, bendix pads are shit house, getting some QFM HPX once im paid in about 2hrs.
Haha my mx5 wheels were white, too much brake dust and like you cleaned all the time. I gave up and painted them black! Easy as now!
Qfm's are great!
and yesterday arvo at daleys point / empire bay a white r33 gtst i think, plates HER25T, and im pretty sure a chick was driving.... go figure!
thats Ella, she's mad
spotted a white 34 GTT at Killcare Beach on christmas day and exchanged a wave with the driver of a white series 2 33 in Kincumber this afternoon
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
