Hey guys i am looking at putting on new and better rotors and calipers on my gtr.i was told to get wilwood kits and that they are the best but pretty pricey. I dont think its worth getting the best but i dont want to get an ok set i would like something that is going to have the stopping capacity and last a while not 6 mnths. The car will see track in the near future but would be a 50% road and 50% track. what other brands are the ones to go with ? and what else is involved with better rotors and calipers ? like do i have to change any oil lines or type of brake fluid ? that sort of thing ?
cheers.
Willwood make great calipers and they make cheap made to a price stuff. They make too many calipers in my opinion and relegate themselves to the too hard basket unless you have really dont your homework. Their good stuff is good but as you said expensive.
Budget is king with brakes, consider what you are willing to spend and go shopping, as budget will dictate. New you will be looking at up to 4k for fronts and similar money for rears, but common rear upgrade is just the GTR Brembo, or the N1 rear which uses bigger rotors again with a similar Brembo two piston caliper.
The 50% track and 50% road thing is all in the pad selection. If you have enough rotor to dissipate the heat then you can get away with a pad that may do both...but the trade off is wheel size requried to run brakes, whih means expensive rubber, more unsprung weight etc etc. So, finding the right brakes at the right price sux :D
i assume when u say gtr brembo theyre from the brembo brand ? iave got which look like dba ones on the front but theyre on the way out and stock on the back so i mite investigate the brembos.as for price. i dont like to put a price on brakes. i need them to stop so to me its worth spending the extra money on something good. but thanks for the advice.
But what power is your car making? What tyres, what wheel size what suspension? You may find that being an R33 that you can get away with good quality pads and decent vented rotors, at a minimum DBA5000 but preferably something better
atm its around the 400 450hp. have standard suspension though i want to fix that at the same time as brakes etcc. tyres are 275 all way around falken fk452's something like that.
Considering the tyre and suspension, i would suggest you just get some good pads, and good fluid. Remove the dust shields and consider some braided lines. Though as Lotus will suggest...dont let me anywhere near youcar come fitment of said goodies :/
Spend you money on better suspension rather then too mcuh on brake hardware. If your rotors are shot then consider some DBA 5000 or preferably direct replacement 2 pce Endless or Project U rotors. As for pads i have really liked Endless CCX, though its possible they are hard on rotors. Though my car having problems with DBA 4000 and RDA rotors and the CCX pads is hardly enough evidence to support that theory :(
I trial fitted them to my car. Nice kit, basically an AP kit, only you need to make sure you get the 355mm kit and not the 330mm kit. Difference being the 330mm kit is 26mm thick and the 355mm kit is 32mm. On an S13 etc the 26mm thick rotor may be ok...but on larger more powerful cars you really want the extra width in the rotor...i think:) They have a loyal following and i will admit the rotor hats are beatifully designed
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
