i know there is a thread on this... i had a read but can't find my exact setup.
just curious... cheers.
Car: 89 R32 GT-R
Mods:
Fresh engine -
-CP Forged pistons
-ARP Head studs
-Metal head gasket
-Stock rods
-stock cams
-ACL bearings
-full reco head (all stock)
-N1 Oil Pump
-New water pump
-stock fpr and fuel rail
-BOSCH 023 pump
-Garrett TO4z (.84 rear housing i think)
-Turbosmart 50mm Ext. gate
-Power FC
-Z32 AFM's
-Blitz 700cc injectors
-HKS Pod's
-stock cooler with HKS piping
-3 1/2" exhaust from turbo to rear cannon.
a rough guess anyone?
cheers.
- Elec boost controller to come.
https://www.sau.com.au/forums/topic/241423-power-estimate/
i'd say he'll run out of fuel before he hits that.. also need some pretty decent headwork to pull that sorta a power figure from a t04z... not to mention that hes running stock rods, which are a known weakpoint in the rb26's
if you push any more than about 350rwkw you risk bending a rod. not sure how much that fuel pump can support either... you should be talking to your engine builder/tuner about this.
https://www.sau.com.au/forums/topic/241423-power-estimate/#findComment-4214456
FAIL!
Plenty of strong engines out there using the std rods. That are actually quite good and can support those power levels quite easily.
https://www.sau.com.au/forums/topic/241423-power-estimate/#findComment-4214531
^^ agreed.
bent rod @ 350rwkw... not a chance.
Plenty of CIRCUIT motors with BIG RPM 380rwkw+, stock rods.
I dunno where you get a known weak point from. I've never even seen someone post here since 2002 about bending a GTR rod thats how good they are.
https://www.sau.com.au/forums/topic/241423-power-estimate/#findComment-4214638
i dont know any people risking a $6-8k forged motor putting out close to 500hp on standard rods.. maybe its a Vic thing ? :) For the sake of <$1k, its worth the peace of mind. weakpoint was referring to the fact that the block and crank can take 800hp+, and stock pistons will generally withstand quite a bit too (if you replace the rings).
Im not saying they will fail @ 350.... but your getting close to the limits imo. each to their own, its your motor !
Regardless, it seems to me that your three quarters of the way through a build. Do yourself a favour, save up a few grand and finish it properly. Rods, cams, port+polish, some other headwork (valve springs) and the fuel system and you can hit 600hp+ safely and it will drive better. Although keep in mind 700cc injectors would be getting pretty high duty cycle to try and push out 600hp... i'd be thinking about upgrading those too (shouldnt cost you much if your happy to sell yours and buy second hand). else, just keep the boost to ~21psi and enjoy your 550 horsies
https://www.sau.com.au/forums/topic/241423-power-estimate/#findComment-4214786
People have done 440rwkw consistently on GTR Rods (ala-Paul)... and he's not the only one.
Plenty of GTR's getting around with close to 400rwkw, stock rods.
So thats another 100rwkw, or what, another 180odd hp @ the motor, nothing to sneeze at, at all in my book.
Why spend $1000 if you dont have to though?
Its like say spend the money on cams, you dont need those either so why spend the $600odd+labour?
Same with Plenums ($800+) and everything else, if you dont need it and stock is perfectly fine... stands to reason that you use it
So you can kinda see my point.. suddenly $1000 can turn into 3k+ for no real reason other than spending it
https://www.sau.com.au/forums/topic/241423-power-estimate/#findComment-4214833
Engine build is done, its cost me alot to get it this far, i was spending money on other area's of the car not only the engine, so money was going quick..lol.. so i just replaced the things I thought really needed replacing, i had no power figure in mind at the time, but after each mod i did, it seemed a waste to not upgrade the next thing in line. (this can continue on and on.... cams, head work, etc. but money doesn't continue on).
and that (1st post) is what i ended up with.
400kw would be great... i only had about 200kw before the build.
so would my fuel pump be upto the 400kw or so?
cheers.
https://www.sau.com.au/forums/topic/241423-power-estimate/#findComment-4215084
my engine is currently being built atm aswell
im looking for about 350kw+ @ wheels with about 20 psi
hopefully i can achieve it.
the sort of work that i am doing
upgrading turbos to
GT2860
PowerFC
Forged Rods
Forged Pistons
Sard injectors
Sumb baffle
Metal head gasket
N1 oil Pump
and alot of other little gizzmoes.
let me know what you guys think.......
https://www.sau.com.au/forums/topic/241423-power-estimate/#findComment-4215312
Cams, fpr and intercooler are proberbly the ownly limiting things, all will start be a pain before 350awkw, rods with good tune should take 400awkw, 700cc should be same.
Do your engine a favour get get rid of the HKS pods if they are the foam type as they don't seal real good where the foam weets the plastic.
https://www.sau.com.au/forums/topic/241423-power-estimate/#findComment-4215348
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
