hey guys i no this is the wrong place but i have got a vn ute for work since i gathered i coulnt afford a gtr i got a cheep ute for work n bak and im gona fix up a 31, neway off topic. the vn when i put it in reverse i get the thump into reverse and it dosnt reverse if that makes sence sometimes it takes up to 10 min to get in reverse if you no what i meen. I just wana no if any one has encounted this issue i thought it would be somethin to do with the valve bodies, but im not to sure i no its a commodore but it annoys me when no reverse, any help will be appreciated. Thanks guys. :D
https://www.sau.com.au/forums/topic/241722-trans-not-gettin-in-reverse/
ive got the same problem on my r33
put in the MV shiftkit valvebody, lost 4th... got that fixed all was good.
then all of a sudden i lost reverse.
car thinks its in reverse but wont engage the gear, no backwards motion.
taking it back to the shop to get it fixed.
ill let you know what it was. may be of help
nuh the tranny has been services it is a auto but i was told that the seels harden up which cause it to not engage reverse when hot, but yer its really a pain i dont wana re build it. thanks for input guys also ny more help will be appreciated.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
