Have just had my car tunned 98 GTR
list of mod
steel wheel turbos
HKS evc boost controller
Hard intake and cooler piping
cooling pro fmic 80mm
tomei fuel reg
std injectors
std afm
std fuel pump
manifolds
std dumps
3" fronts
3" exhaust straight threw atm
lightened flywheel 12lbs
pfc
cam gears
after tune got 260awkw with injectors at 96% duty and didnt want to push them any harder had fuel pressure bumped up to 70psi running 1.25bar have included dyno sheet.
is this a good tune? have read others dyno resaults and some getting 300awkw on std injectors why are mine maxed out?
https://www.sau.com.au/forums/topic/241868-gtr-dyno-tune-260kw125bar/
list of mod
steel wheel turbos
tomei fuel reg
std injectors
std afm
std fuel pump
manifolds
std dumps
3" fronts
pfc
cam gears
Try running less boost and more timing. And are you sure the tuner wasn't just winding in the fuel to compensate for a dying pump? Maybe a new pump might help to keep things in order. But without seeing the car, it's anyones guess really.
I did not read this before.. but I agree your fuel pump needs upgrading.
I would also replace injectors with new 550-700cc depends what you want to achive and headroom.
Replacing old parts for new is a good thing and a safe thing to do.
std fuel pump
Hey,
It should be easy to figure out whether the pump's not up to the task - get a graph of
fuel pressure on one of those runs (or have someone watch a gauge if it's in the engine bay),
if it falls off at maximum flow your pump needs help.
Regards,
Saliya
I also think dying fuel pump.
Silly to bump the rail pressure without checking the pump is ok first.
Very dangerous infact as in a few weeks the pump could be in even worse state then you'll really have more drama's
Seems a little low..
Stock turbos, injectors, no gears, just exhaust/dumps & power FC made me 250kw at 12 psi.
That’s actually a little high… 250rwkw is generally a result of 1bar.
fuel pump seemed fine i watched the gauge and held pressure strong but at 85psi its was bouncey on the gauge so that why we wound it back to 70 and when on a dyno run it woundnt drop back down or the neddle wounldnt go bouncey at all. but i have just bought a 044 im setting up a swell pot in the boot because i do hill climbs but really dont wanna drive 400km to get another tune on it already have already drop $1000 into tuning it.
when put this new fuel pump in will it stuff up all the a/f ratios?
Very much a potential yes.
If your running a higher than stock fuel pressure to counteract a dying pump
And then put the new pump in, you could find that its running even more pressure = bad.
Ha, yeah they need to learn how to scale their graphs a little better...
Did you run a flow test on it? No point having pressure if you got no flow.
Of course the a/f will be affected, if people are running 280 maxxing the injectors out, and if yours are on 96% then you technically should have almost 280kw worth of fuel going into it with a decent pump.
and theres no way you get 260AWkw running standard turbos and under a bar HAHA.
well he said "steel wheel turbos" not standard turbos. (or did you mean someone else?) certainly my 32 n1s give me about the same at 0.8 bar which is all we are allowed to run.
travis we make very similar power in our targa car at 0.8 bar using standard injectors, standard fuel pump, standard afms etc. we are also running over 90% duty cycle which is high enough for me considering how the car is used (no point pushing it to a dangerous level when fuel quality and temperature can vary so much). Not sure where these 280 or 300kw numbers are coming from standard injectors unless maybe they mean rwkw not 4wkw?
definately check the fuel pump is OK to be safe but we don't get any more than you do with new pump, clean and tested injectors and nismo adjustable fpr. easy to check since it sounds like you have a fuel pressure gauge - pressure should climb with boost right to the top of the rev range...if it drops off up high you have fuel pump or fuel pump wiring problems
yes i noticed it to that it only goes to 140kph, the tunner said something that it wasnt getting traction would this be the case and he said his rollers where warn? i will be putting a swell pot in and a 044 pump and i re-run the wiring aswell.
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
