Item: Xenon lights with loom
Condition: WORKING CONDITION
Price: make an offer over $100
To Fit: came out of a 34 GTT so im guessing it will fit 34 GTR to and all 34s that came with xenon
Contact: pm or sms on 0422225532
Comments:
Iv got a set of Xenon globes with the looms that came out of my R34 GTT when it was complied
Was told it was working when it was taken out and since then its been carefully wrapped up and stored for the past 2 years.
Comes with looms and 4 globes im guessing 2 for low beam and 2 for high beam.
pics will be posted later tonight of the actual item but they look like these anyways for those who dont know http://www.skylinesaustralia.com/forums/post-a165948-
Willing to post at buyers risk and expense.
Im also up for trades as I am after the following:
Boost gauge (prefer in PSI) or a Turbo timer
ta
Ash
https://www.sau.com.au/forums/topic/241892-r34-gtt-xenon-globes-with-looms/
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
