  • Replies 100
na, I was thinking the guy that started a similar thread not long ago that had a so called cop (Hot Fuzz) respond to it
a stated at the start i am new to this whole import/performance thing, so please excuse my out look.
and no i was'nt on here b4 with a differnt name.
its ok sweet, welcome anyway to the home of SAU SA where.............. i should stop now but welcome.
but to us this is a very funny topic
cheer for the welcome. and the only reason i posted this topic is to get a bit of thought from others about the subject. many ppl complain about anti hoon laws and police harassment but noone wants to stand up and say we need more than one place to go a month...... like i said just testing the waters. :) chose the wrong subject but......
they wont do it but you can try andtry but it will fall on deaf ears your best bet would be to go see klem and ask for more track days and with enough people that want more he might open it 2 time pr month cause he does love his money
good luck
good luck
how many ppl would be up for that. from what i understand most track days have limits on the amount of cars, and they book out really quick. if there were more days open would it minimise the dick heads on the streets .... i think it would, that may cause less police fines for all of us!!
i think Clem needs to re-surface the track podgy old bastas.... yesm. Welcome Aboard Mick
valiant idea buy yeah councils don't want to listen if they get us all off the street they loose revenue
they really don't care about safety like they would have to general public think
its a pitty all import owners are tarnished with the same brush. it sux a bit cause drifting is one of the fastest growing sports in australia ( the world for that matter) it would be nice if some of the local parliment members got on board for us.... they would get my vote :)
:) this is funny :rofl: it will never happen not while there is mallala and the cops have hoon laws :thumbsup:
:rofl:
Will never happen. EOI does not = numbers.
You keep beating that dead horse ... you'll end up beating your head against a wall. There is a new motorsport park in the works. In a few years we might have more opportunity. But right now? ... nope.
create a new park open it up after hours, $20 entry, cops will just put defect stations out the front! we are all labeled, undoing a lable of imports being hooons will never happen, your trying to fight through a council, when the gov(popo) will jsut destroy it at the end of the day!
like ppl have said bud WELCOME
on a bad note theres realistically no hope of this happening, just think if 1 driver loses the car into a couple hundred ppl...
i even think getting more track days will be a push, due to consistent numbers of ppl the way it is now clem knows that itll be pretty much full every even if he bumps it up to 2 nights per month theres a high possiblity of the cars spreading out over the 2 events and not being filled and therefore not being viable.
gazanats was on the weekend so we may only be a few months away from A.I.R opening up for drift prac days again keep that in mind!
well there is lala! the streets are for the public and it shouldn't be closed off for something like drifting especially when there's a venue/controlled environment for it already!
if you don't agree then tough bickies because that's the way it is!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
