Hey all,
Ive searched through the RB26 modifaction section and have come up with wht i think should be ok for what im after..
But not being that knowlegable the numbers and turbos all mix into each other etc etc lol...
Im just after someone to look over what i have already got and what i am currently searching for and either say yes that would be sutible for what im after or no mayb you should look at this..... etc.
First off i should say my car is a 1995 GTR R33 non-vspec.
What im after is decent response as its 90% a daily driver but still be good enough to shoot down the quater mile (if adel ever gets a bloody strip) in decent times. 11s.
Defiantly want over the 300kws mark but i guess not by to much.
Be able to have a fairly safe tune and still get those two above things.
These are the mods i have currently and dynos at 261kws -
Modifications:
Suspension New blisten Shocks, Lowered King Springs
Work XD9s 18 x 10 +18 with Kumo 275s all round
Kakimoto Catback Exhaust, Just Jap front pipe, high flow cat
700cc SARD injectors
TOMEI cam gears
HKS pods
Custom Cold Air Intake
Trust Intercooler
Nismo Fuel Pump
Power Fc and Controller
Greedy Profec 2 Boost Controller
Twin Plate Clutch
HKS boost gauge
Carbon Wing Blade
And these are the mods i am looking at getting to hopefully finish off my car to get out of it what i listed above -
2860r-5 Turbos
Bosch Z32 AFM's and plugs
Tomei Dump Pipes
any thing else i may need?
Would this set up get what im after?
Any ideas or suggestions?
Any help would be great as i dont want to go ahead and find out ive fallen short.....
cheers
Adam
https://www.sau.com.au/forums/topic/242050-33-gtr-finalising/
yep, that will be a good package mate. the only thing I would add would be a nice oil cooler kit (get one that mounts in either the left or right duct in the front bumper, not the ones that mount in front of the radiator).
you could also consider nismo AFMs over the Z32s. no plug mod needed and no mod to your intake set-up either. they are basically a Z32 sensor in a standard casing.
fked if I know for sure, but for just over 300kw you want the smaller ones (I think the -7s). the other ones are more like a 2530 and will give 350-380rwkw and are more laggy.
-7s 300-330rwkw
-5s 360-400rwkw
You can run 11's on the stock turbos, so with -7/R31N1/GT-SS, you'll run 11's without a worry.
And yeah, Nismo AFM's.
Stock dumps are fine from what ive seen.
Im using them (250rwkw @ 12psi) and there are cars over 300rwkw with -7's using them also without issue and no noticeable performance issue.
I wish i had the coin to finish my setup for the full 20psi+ just to show that stock dumps can do it, overlap with a 'dump equipped' car and show there is no difference :)
ahhh cheers for that, ill start to look for -7sand nismo afms then instead. glad i asked now.. looking through the many pages just got a bit confusing for me lol...
and dumps.... i hear what your syaing... lol.... but id hate to find out later i should have had some. and seeing as ill have the turbos off and out i might just add them... lol u know just in case lol
my problem is tho and yes will sound stupid, but im not 100% sure what type to get as i have heard a few not being drop ins. Then you needed them grounded off new shimes etc etc etc
I just didnt want the hassel. But yer wouldnt mind a set
Cams again... debateable (more so than dumps)
IMO a set of cam gears properly dialled in, all you'll need
Yeah, agreed. While the lumpy idle is tough, it's completely unnecessary. There's a black R32 GT-R that I'm reasonably familiar with that runs ~370 RWKW on standard cams.... :(
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
