Basically I have bought an series 2 RB25DET 4wd from a Stagea
Just wondering if leaving the front diff from the stagea with the rest of the driveline being standard gts4 would the attesa system still work fine with the different diff ratios (if there is any? presuming that their is, stagea was auto btw)
Also, if anyone who has done this conversion could you tell me what else will need changing? will be putting 25det loom and ecu in, manifold and external wastegate on, and a front mount intercooler on at the same time. So should be a good improvement over the standard rb20det
Thanks in advance
Cheers
https://www.sau.com.au/forums/topic/242104-r32-gts-4-rb25det-conversion/
It's a different ratio (4.083 v 4.375). Therefore the rears will be turning faster than the fronts, causing the ATTESSA to activate drive to the fronts, and the the front will want to accelerate away from the rear. Not a good idea.
I would recommend you get hold of a Stagea rear diff assembly and have the crown wheel and pinion swapped over into the GTS4's centre and housing. (The torque out of the RB25 doesn't justify the 4.375 ratios)
You see, I read all these things. I know the diff ratios are diff from 32 and 33. Icontinue seeing these threads pile up with the same information.
But when I did my conversion. The ratio's were the same. I dropped in a DE which may have been the diffrence. Lower gear ratios for a less powerfull engine. Makes sence.
But yes, the easiest way to do it is as Elk said. swap the wheel and pinion over.
Or get a 4.375 rear diff. The 32 gearing is ver short as it is, depending on what your planning to do with the car you may find it a better option to change to a larger diff ratio.
Edited by GTS4WD
No, the R32 already has 4.375 rear diff ratio (and a 4.375 front diff ratio). The Stagea has 4.083 (@ both ends!)
There are 2 options:
1. Swap the front diff from the RB20 into the RB25, so you retain the factory R32 4.375 ratio.
2. Swap the C/W and Pinion from a Stagea REAR diff onto the diff centre of the R32 REAR diff (the Stagea seems to run an "open" rear diff, not a Viscous Coupled rear diff like the R32). This way, you get the Stagea 4.083 ratios.
With the torque of the RB25DET, I would go for option 2 while you have the opportunity and everything is out of the car. (Because I've been there, done that)
With option 2, you will need to change the speedo drive gear in the gearbox to a R32 GT-R unit, to keep the speedo readings correct.
Ok sweet thanks, does anything else run the 4.083 rear diff ratio that will still fit upto 4wd driveline?
and if i went with option 1 (rb20 front diff) what sort of rpm would the car be sitting at at 100kph in 5th gear (currently about 2900rpm, pretty high for a 2ltre i think)
will eventually want to put a gtr driveline in it at some stage, not at this point in time though, want to get it back on the asap now.
also, my right front CV joint is f**ked, what CV joints do they take?
thanks for your help, good to see a few GTS4 owners on here aswell :(
Not that I'm aware of.
Should be exactly the same because you'd still have the factory driveline.
in mine with stagea RB25 and box and GTS-4 diffs it revs at around 2880rpm at 100km/h and 3060rpm at 110km/h dosen't feel like the engine is revving its tits off (its a pig on fuel anyway so fuel consumption remains at around 18l/100)
Edited by bozodos
Ohh and also, to swap the diffs over, do you need to swap the whole sump or can u take just the diff off buy itself?
You can swap just the diff itself. You MUST swap both the Crown Wheel and the Pinion - they are a matched set. Have fun undoing the pinion retaining nut!
Hey guys, i have a r32 gts4 with a stagea rb25 conversion. I had a work shop do the conversion and they had a few issues, one of which was the trying to attach the rb 20 front diff/sump to the block (rb25) eventually they ended up machine the bottom of the block to fix the front diff axial across the bottom of the sump. I am pretty sure, thats what they did. and now if i am full lock or accelerate quickly i get 50/50 touque split which i assume is from the rb20 rear diff and the rb25 front diff! umm thats a bad thing........oh shit~
ok sweet, so how is the diff attached to the sump? i thought they were one piece, so ur saying the rb20det front diff will just bolt upto the rb25det sump?
Remove the cover plate off the diff housing, remove the drive shafts, and the diff centre basically falls out. To undo the pinion nut, lock out the flange against the block with something like a cold chisel, then use a BIIIGGGG breaker bar to get the leverage to undo the nut. The pinion comes out the same direction as the centre.
Use GTS4 rb20det sump & diff and bolt that on your stagea rb25det motor. It bolts straight up. Done it before. RB20det 4wd ratio's are shorter and more fun. Hence alot of GTR's convert to GTS4 ratio's
Also listen to blind elk. he knows what he's talking about and helped me ALOT via PM's last year, while doing this very same conversion
ok sweet, bolting the rb20det sump and diff on sounds a whole lot easier if it just straight bolts up. any probems with running rb20det sumper coz maybe be smaller or anything silly like that. lol soz bout all the n00b questions but im learning :P
Cheers guys :laugh:
  • 5 weeks later...
i have heard both.... that it is a same bolt on but i can tell u, some of them dont! i had it done at opition one auto and they showed me the difference between the two sumps! hey i had to have the block machined
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
