I just put redline (smurfsblood) in and I it was 3.5 quart bottles (3.3 litres approx), but do a search its been covered before many times, in fact I think I looked it up on here to see how many to order.
what oil should i use? im trying to stop my 4th crunching? redline or royal purple? which is the better to use.
Redline did shit all for my crunching gearbox.. absolute waste of money
try a simple gearbox oil change first $30 and see if that fixes it.. Castrol VMX80
btw the gearbox will take around 3.5 - 3.8 litres... You just keep filling until it comes out of the filler hole.. (make sure you undo the filler hole before dumping your old oil)
Ive changed it many times before :P
Edited by MotoMan
Yep just short of 4L.
I tried Castrol VMX80 last time, it worked fine... but I'm thinking of swapping it out with Castrol Syntrax which is the much more expensive fully synthetic product. It's about $30 per 1L bottle at any local auto store.
I filled mine with 3.8l of redline. Only been 250km since the change, so i cant really comment on any difference in crunching/etc (mine doesn't crunch often anyway). Ended up getting it for 22$ a quart :(.
thanx for all the comments guys
yeah i found a fairly cheap supplier with redline stuff
he is doin me 4ltrs delivered for $112 which i thought was ok.
all the auto shops were around $150
going to get oil change done next week as my 4th is just about impossible to change into unless u double/triple clutch it
Just a little update.
dropped the oil this afternoon out of the box
and to my suprise 3 syncro clips stuck the to bung :)
so i aint going to put $150 worth of redline oil in.
i dont know what to do. what are rebuilds worth on these boxes?
Bearings/seals and 4 syncros is around $1500-1600
thats drive in drive out price..
and to my suprise 3 syncro clips stuck the to bung :D
lol... i had this exact same problem, 3 clips stuck to the magnet, must be a common problem on the RB25 boxes?
I got gear crunching in 3rd and especially 4th... Just for the record, I use VMX80 for the gearbox and diff, and in my books its a pretty good oil...
either way, looks like ill have to get a rebuild soon.. ;)
Edited by EVL-R33
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
