man im greek heritage married to a skip (aussie), so im not the racist bigot here!
seig heil! get your shit straight rhys, are you a racist?? it seems so. and by the way those that how me know how hard i F@#KING AM. Passionflower. i dont appreciate derogatory remarks of ppl stereotyping wogs as a-holes. so take a chill pill man.
  • Replies 157
a dogger,??? what australians are dogs now? we are the best mate, dont forget that! aussies rule! proud much??? i think so
calm down jonnyboy thats what US WOGS call you skips!
oh btw Iam PROUD of being aussie and love this country very much.
conversation about a japanese car turns into chat about aussies and wogs nice :down: being a aussie that looks a like a wog i must say this convo is sic mate ;)
http://au.youtube.com/watch?v=6k2r6mKYn5Y
go back to england you stupid skips :D forgot what side im on
http://au.youtube.com/watch?v=R3NhuPIa7l4
ok im done now ill shutdup :P
Edited by Inline 6
And I got enuff wog blood in my veins too. What, do you think u got the copyright on slang? Relax. I could give a rats arse if they call me or anyone else a wog, its all about the context and considering the bloke wasnt attacking anyone on the board, I think you're taking this way too personal.
-D
are you 12, i mean honestly???? either your 12 or you are as thick as 2 short planks.....
1) YOU are the only one throwing the "race" word round here, no one else
2) seig heil???? could you be any more offensive to the jewish/black/german/australian population??? what does german have to do with the subject?
3) get my shit straight??? you came in here acting like a little bitch over a word that is not a racist term
4) am i a racist? no. but im fed up of pretencious lil cry babies like you who make race a big deal
5) i think you are the one in need of a chill pill princess, so take a deep breathe and get over yourself.
6) your statement "wogs built this country" is highly offensive and racist to all of the great australians of english decent who died making this country what it is
f**kin child
f**kin child
ha ha youre really funny! MATE i think you should get your'e shit straight ya BIGOT.
*sigh* is that all you have? i mean you go making race a big deal, start ranting on about some nazi shit then call me a bigot................ go get beaten by a mirage again or sumthin kid
