  • Replies 181
Posted Images
people have mentioned they want a Sunday.....
I'm not suggesting a change of any dates, just FYI's.
Sunday 14th is SDMA Hillclimb BBQ presentation lunch at the track. That may take a couple of ACT SAUers out.
Sunday 7th is Bathurst Speed Weekend, but at this stage, I think that only takes out James?/Chris/Mark and I.
count me in for the 21st
I'll be back from big city lights of sydney than would be awesome to catch up with the canberra crew
two years back we just went for a cruise out to the cotter and had a bbq there.
It short sweet and simple still involves driving and gives a chance for socialising round the barbie in fake titted aprons
well we need a time and a destination.... not much point worrying about that until there's enough people to go ahead... so far the tally seems to be about 5 ;)
lol Mick you'd need super human powers, not just balls, to speed that stupid bbq up ;)
yeah except i had to cook the farking thing.. none of you boys helped!!! lol
it was also the worlds slowest BBQ... I think the cruise took 20mins and the BBQ took about 3 hours ;)
but in that 3hrs we had a riviting conversation about pink skylines from memory hahahaa
