  • Replies 102
Posted Images
What's the install like on these? Do you need to solder or anything or is it all plug in? I'm pretty interested but only if I am confident in installing them myself.
What Phil said :)
kk
Well I was thinking of just going with 4300k but you mentioned somewhere 5000k?
Have you got any pics of 4300 or 5000 on a car? 6000k seems a bit bright for night driving on the streets.
Do the HID's work for both low and high beams or just low beams? Are my high beams still useable if I get the HID kit?
Sorry for the questions man! Maybe shoot off a PM to me if its easier.
Kelvin rating has nothing to do with brightness.
All kits are 3x times brighter than stock halogens.
Kelvin rating is the colour of light it produces.
For example:
post-32255-1228864757.jpgpost-32255-1228864776.jpgpost-32255-1228864909.jpgpost-32255-1228864928.jpg
Kits are low beam only and yes you will have normal highbeams.
I can also get a higher quality Digital HID kit from Bosch and Siemens.
They come with higher quality bulbs and new digital ballasts.
These digital HID kits are latest technology.
These kits are $225 delivered.
For those who dont ming paying extra for quality then these kits are for you. :D
Interested in one of these kits (6000k), what kit would i need for my 32 GTR?
Thanks,
Dan
Thanks,
Dan
Im not sure Dan, you will have to find out what bulb suits your car and let me know.
Once you do PM me and we will go from there.
Dani Boi your kit has been ordered :)
Thanks mate :P
Thanks,
Dan
R32 bulbs would be the same for R32GTR I would think, if that's the case they are H3's, but double check that first!!
Thanks mate :P
Actually there are a few types for 32s,all depends if you have reflector or projector headlight assemblies.
So yes please check to see what bulb types suits your car before ordering.
:P
Thanks for that guys- I havn't been able to check headlights yet as I work away a month at a time and the guy working on my car hasn't got around to checking globes yet!
Ive attached a photo so if possible could you please confirm projector headlights?
Thanks,
Dan
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
