  • Replies 134
Posted Images
I really like that location gus :D Nice pics too
Just one quick suggestion - i reckon a tad less exposure on these would have been better.
What settings did you shoot it with? Exif data isnt intact :D
Camera Make: SONY
Camera Model: DSLR-A200
Image Date: 2008:11:11 21:55:55
Flash Used: No
Focal Length: 35.0mm (35mm equivalent: 52mm)
Exposure Time: 15.000 s
Aperture: f/5.6
ISO equiv: 100
Exposure Bias: 1.00
White Balance: Auto
Metering Mode: Spot
Exposure: aperture priority (semi-auto)
exif shows for me
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
