So if your going past Berwick on Saturday morning and can pick me up that would be great...
I'm leaving from the City / Docklands, if you can get into town, i have an empty passenger seat.
Planning on returning on Saturday afternoon tho, don't know if this is any good to you.
But im going up tonight now with Shane ..VSPEC-33
Cool :banana:
Means I have a spare seat if anyone else is interested. Leaving the City about 6:00am (Via the ring road meetup) and aiming to be back in Melbourne by about 5:30pm.
Any of you guys have UHF CB's? if so, which channel?
adrian, what suburb you coming from mate??
West, just confirming, i'll see ya at Shell, cnr Princess/Warrigul at 5...
actually, if it's just us 2, what suburb are you coming from? I'm coming from sandy, so i'd be driving up Warrigul with shell on my right and to be honest, i don't know what the driveway is like, might be too steep for my car to get up without blocking oncoming traffic for a few mins :banana:
we can cruise up the beach rd, jump on to the west gate from kingsway if that might suit better??
all this talk of shell, don't people want BP petrol stations?? :P
cool, well, in the absence of the OP, i guess we'll just follow the details of the first post.
there is the pre SE meet, then it seems most people will meet at the ring rd Macca's at 6.15
update guys, i'm meeting the se pre meet crew at CALTEX, KINGSWAY (opposite BMW).
so i'm not going to be at the original se pre meet, and will aim to be at caltex kingsway at say 5:25, if you're going to rock up there, i'll be in the black 34
Guest
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
