Ok so i have gone out and ordered a full Impul kit with a carbon bonnet with a Ztune style vent in it, My question is has any-1 got a pic of a white R34 with a carbon bonnet or have a R34 with a carbon bonnet that could post some pics up for me :blink:as im alittle un decided if i want the boot aswell, also looking into the carbon eyelids if any-1 has a pic of with a carbon bonnet that would be great
Here's a pic of the Mines R34 GTR with a Carbon Boot lid.
god that car looks awsum, i thought the carbon boot would of ran all the way down the back off the boot if that make sense ?
Ah yeah shite!
LOL! I know what you mean I think I gota find that pic but maybe on a R32.
But if you do get it, it looks nice, real Race Car style.
to all you guys who are interested in CF trunks or spoiler, try searching for JPcarbon on ebay. I have received pics of his products and he does have full CF wing for r34, CF trunk as well. Been wanting to buy something from him but too bad, mine is a sedan. :P
darn!! why didnt i see that when i had money... :D its sold now BUT at least i know CF boots DO exists for r34 sedan!! :D
yea, the jp carbon is the guy im talking about. hope that helps.
Edited by uncouth32
  • 3 weeks later...
Did you fit it yet? does it fit properly? whenever I see a ztune or other style aftermarket hood and I ask,
it is always "nah, mate, it doesn't fit too good".
hey.
I am currently looking at putting a carbon boot on to replace the standard one that has the old spoiler holes in it.
I have seen cars done with carbon bonnet & boot before, but i think it depends on the colour of car. But either way think it looks pretty cool.
I have spotted viva garage selling carbon boots for R34... check them out. http://www.vivagarage.com.au/
Cheers
Clint
pretty happy with the fitting, body kit is getting a tidy up and prep for paint at the moment :)
Edited by ian_and1
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
