Hi Guys,
I went to the pits today to get a yella taken off for bald rears, and the dude failed me cause he said the rear diff was too harsh and clunky. I told him it was the standard nissan 2 way diff but he said, doesnt matter, get it fixed.
So apart from taking the shims out (converting it into an open diff), or putting in a differant diff, what can I do to quieten it down heaps??
Ive done a search but havnt had much luck finding anything usefull.
Can anyone with experiance on 2way gtr diffs recommend a good lube that will shut it up??
I really cbf'd pulling the diff out!
thanks guys
Steve
Edited by PHATR32
https://www.sau.com.au/forums/topic/243096-r32-gtr-diff-very-clunky/
You *could* machine the housing to loosen it up a little (diff rebuild).
OR you might be able to use a different oil or some LSD additive to quieten it down a bit...(not sure of the exact details, I've seen the product names before and there's a sticky on recommended oils)
Hi Guys,
thanks guys
Steve
Yep, try some redline 75/90 gear oil... or 85/140w - they have a friction modifier built in which might smooth it up.. on top of that you can get a small bottle of Redline Friction Modifier and add 10ml at a time..
thanks for that, ill give the redline a go before i do anything else.
I know if i pull the shims out itll end up being open diff, which is something i dont want!!
cheers
steve
I wouldn;t be putting Redline in your LSD to shut it up, have used this oil in the same diff as yours and it made mine more knocky than usual (diff is in very good nick to boot). Try Castrol SAF-XA (fully synthetic) , made mine MUCH quieter + I get longer change intervals.
Sort of depends on "which" Redline you use.. maybe you used one of the 'Shockproof' variants? or did you use the 80-140 Gear Oil?
But yeah it doesn't have to be Redline, just needs to be a good oil with friction modifiers built in. I was just saying Redline because it is what I used and it sure worked for me, and I used the 80-140 gear oil in a Nismo GT Pro.. I'm sure the SAF-XA would work well too.
80-140 gear oil, I used & still use shockproof lightweight for the gearbox (no dramas with this). Sydneykid recommended the Castol SAF-XA to me some years back based on what he used in his race cars, it's good stuff.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
